- #281
ghwellsjr
- 150
It's easy to misunderstand how length contraction combined with time dilation would result in the same speed (for light) being measured for a moving clock/observer as compared to a stationary one. Let me explain:Grimble said:...
So I resolved to look at one of the most common starting points: the moving light clock with which I am sure you are all familiar.
Also I was concerned about length contraction (getting smaller) and time dilation (getting bigger) for a moving object when speed = distance / time.
You seem to understand how a light clock works. In a rest frame where the speed of light is the same in all directions, it is easy to understand that if we place two mirrors a fixed distance apart in any orientation, the light will take the same time to make a round trip back and forth between the mirrors, no matter what the orientation of the two mirrors is.
Now we consider a light clock in motion. First we position the two mirrors so the light reflects back and forth at right angles to the direction of motion. You probably understand that the light takes longer to traverse the path between the two mirrors because it has to take diagonal paths and you can probably figure out that the total round-trip path is gamma multiplied by the previous path length (when the light clock was at rest) multiplied by 2 and that this demonstrates time dilation.
But what happens if we rotate the light clock 90 degrees so that the light is going back and forth along the direction of the motion of the mirrors? Well now if you follow the details (which I'm sure you can), you will need to move the mirrors closer together in order for the light to make the round trip in the same time as it did before we rotated the light clock. This demonstrates length contraction which is the original distance divided by gamma.
Now if we want to calculate the speed of light as demonstrated by this light clock, we might naively say that the speed is equal to the distance divided by the time and since the distance was the orginal distance divided by gamma and the time was the original time multiplied by gamma we should get the speed as distance divided by time divided by the square of gamma. This is what you calculated in a previous post, but can you see how this is wrong?
There are two ways to demonstrate that it is wrong. If we look at the first orientation of the light clock where length contraction is not involved, we use the actual distance that the light traveled along the diagonals, not the distance between the mirrors, correct? In other words, we make mental note of where the mirrors were when the light struck them and we use the actual distance traversed by the light when we calculate the total distance. This distance is gamma multiplied by the original distance multiplied by 2 (for the round trip).
And if we look at the second orientation of the light clock where length contraction is involved, we have to do the same thing as before: make mental note of where the mirrors were when the light struck them and again use the actual distance traversed by the light to calculate the total round trip distance. This distance is again gamma multiplied (not divided) by the original distance multiplied by 2.
If you actually do this exercise you will also see that in the last orientation, the two halves of the round trip are not equal in length--when the light is going in the same direction as the mirrors are moving it is longer, when the light is going in the opposite direction as the mirrors are moving it is shorter, and both these distances are different than the two halves of the distances in the first orientation. And in the same way we can say that the time intervals involved for light to traverse each path between the mirrors is different. It is this difference that is the reason for the relativity of simultaneity.
So you can see that even though we talk about length contraction for a moving object, for the light path, it is actually a length stretching because the light is striking the mirrors at different times between which the mirrors are moving to new locations. The Lorentz Transform takes care of the correct calculations.
