Loop related to Circular motion
To determine the speed a skateboarder needs to successfully complete a loop with a radius of 7 feet, the discussion emphasizes using conservation of energy and centripetal acceleration principles. The skateboarder must maintain a minimum speed at the top of the loop to counteract gravity, which can be expressed as vf²/r = g. Initial velocity can be calculated using the energy conservation equation vi²/2 = vf²/2 + gh, where h is the height from which the skater starts. Confusion arises around calculating final velocity, with participants clarifying that if vf is zero, the skater would fall instead of completing the loop. Understanding the dynamics of forces, including tension, is also highlighted as crucial for solving the problem effectively.
Kikki:)
The radius is 7ft, the diameter is 14ft, the person is 181lb and is 6ft 1in.
How fast does he have to start the loop to be successful all the way around?
How high does he have to start?
Don't need to apply Friction.
Cetripetal Force? Flo Diagram?
I'm not getting how to start or find it. I know possibly kinematics is involved with it.
I also forgot to mention that it is a skate boarder going down a ramp and into a big loop, it was off of jackass, out teacher is made this equation from it by just estimating it. I'm mainly wanting to learn how to do the problems. :] So would you try to find the circumference first? So would the final speed be 0 ? I know that the gravity force is 9.8 m/s/s. A possible equation from kinematics would be final velocity= initial velocity + acceleration x time. But the problem is I would need to know the time.
Hi Kikki:) Welcome to PF! :smile:
I'd recommend using conservation of energy combined with the required centripetal acceleration to stay in a circular trajectory.
At the top the center of mass of the skater should have a speed high enough to match the centripetal acceleration, that is:
vf2 / r.
To achieve that he should have an initial speed dictated by conservation of energy, that is:
vi2 / 2 = vf2 / 2 + g h
vf2 / r.
But how do you exactly figure out the final velocity because I tried it as having it as zero. I also came up with a formula too that I think could work also related to yours.
v2=Tension + mg
If the final velocity (at the top) would be zero, the skater wouldn't be going forward anymore, and fall straight down. Ouch! :smile:
He needs to have a speed high enough to neutralize gravity, that is:
vf2 / r = g
v2=Tension + mg
Huh? Don't know that one? :confused:
What is "Tension"?
The units don't match, that is, v2 is not a force like the others...
Apparently this is supposed to be a forces sum, but consider when it would be applicable and what the directions / signs should be... :wink:
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
