Lorentz Force & Newton's 3rd Law
The discussion centers on the Lorentz force and its relationship with Newton's third law. It clarifies that the Lorentz force arises from the interaction of a moving charge with a magnetic field, and while Newton's third law states that every action has an equal and opposite reaction, this does not directly apply to fields. Instead, the reaction force is experienced by the source of the field, such as another charge or the coil generating the magnetic field. The conversation also highlights that conservation of momentum is relevant, as changes in the momentum of the charge correspond to equal and opposite changes in the momentum of the field. Ultimately, the interaction picture and the force picture provide different frameworks for understanding these phenomena.
ElectricJosh
Hello,
I have been wondering this for a while and have only recently thought to ask here.
The Lorentz force is the interaction of a moving charge in a magnetic field, it doesn't seem to have any sort of physical force applied to it, only the magnetic interaction.
I was wondering, if there is a force being generated by the field on the moving charge, then where is the equal and opposite force as stated in Newtons 3rd law or does it not have one?
Thank you very much.
It is important not to mix up models, in this case the force and interaction picture seems to have got mixed up.
Force picture:
- a moving charge experiences a force from the electromagnetic field.
The reaction force is experienced by whatever generated the field... i.e. another charge.
We don't always deal with that for the same reason we don't always bother with the reaction of the Earth to, say, a bouncing ball.
Interaction picture:
- a moving charge experiences an electromagnetic interaction.
... this is a different model. To get an interaction, it must absorb or emit a virtual photon.
The concept of "force" is not invoked as part of the model here, only conservation and symmetry arguments.
So discussion of forces in this model is irrelevant.
However, we can ask how the appearance of the third law comes about from fundamental interactions - which is, I suspect, where you are headed.
It happens due to the photon interaction involving two charged bodies - one loses the photon and the other gains it.
Newton's laws of motion are an emergent phenomena arsing from many fundamental interactions - they only work on average.
Newton's third law doesn't apply to fields. However, it does generalize to the conservation of momentum, which applies to fields. The change in the momentum of the charge is associated with an equal and opposite change in the momentum of the field.
Likes GiuseppeR7
Hey Guys, thanks for responding.
Conservation of momentum is what I was primarily concerned about.
So there is a reaction force that acts on the object that generated the field.
The two charges example makes sense, but where would the reaction force act on a magnetic field generated by a coil of wire?
The electron charges are spinning in the coils which generates the magnetic field, when the field interacts with another charge outside the coils, does the reaction force try and stretch the coil radius outwards in all directions?
Thank you kindly.
com of coil.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
