Lorentz Transformation Derivation Question
In summary: You can certainly generalize the transformations to include acceleration, but that’s not the problem you started with.In summary, the conversation discusses making a derivation of the Lorentz transformation, which results in the equations A^2 - B^2/c^2 = 1, D^2 - E^2/c^2 = -1/c^2, and AD = BE/c^2. The speed of the origin seen from primed frame shall be -v, and the differential can be computed by treating v as a constant. The coefficients A, B, D, and E can only depend on v and not t or x, and the Lorentz transformations relate the behaviour of one set of inertial clocks and rulers to another
jk22
729
24
I wanted to make a derivation of the Lorentz transformation :
$$x'=Ax+Bt\\t'=Dx+Et$$
The conservation of the quadratic form ##c^2t'^2-x'^2## yields the equations:
$$A^2-B^2/c^2=1\\D^2-E^2/c^2=-1/c^2\\AD=BE/c^2$$
Hence ##B=c\sqrt{E^2-1}##,##D=\sqrt{E^2-1}/c##,##A=\pm E##.
The speed of the origin seen from primed frame shall be ##-v## hence :
$$\frac{dx'}{dt'}|_{x=0}=-v$$
That's where my question comes : how should the differential be computed ? Is it not that now B is a function of v and t with ##B'(v,t)=\frac{\partial B}{\partial v}## and ##\dot{B}=\frac{\partial B}{\partial t}## leading to
$$dx'=d(Bt)=B'tdv+\dot{B}tdt+Bdt$$
jk22 said:
That's where my question comes : how should the differential be computed ? Is it not that now B is a function of v and t [...]
If B were a function of t, your original transformations would be nonlinear, whereas you're assuming linear transformations upfront in this "derivation".
Also, since you're (presumably) transforming from one inertial observer's frame to another (i.e., where the original and new observer frames experience 0 acceleration) you can treat v as a constant when computing the differentials.
[Aside/Rant: deriving the LT by assuming the invariant interval is just plain cheating.]
HTH.
Likes jk22
Well at the end I found :
$$E(v,t)=\frac{-Lv/t+\sqrt{L^2v^2/t^2+(c^2+L^2/t^2)(c^2-v^2)}}{c^2-v^2}$$
L is a constant of integration, a length.
We recover the usual Lorentz factor in the limit ##t\rightarrow\infty## and in other cases the limit ##v\rightarrow c## seems to exist.
But what does t mean ?
There's some misunderstanding though your ansatz is correct. Due to the special principle of relativity your coefficients ##A##, ##B##, ##D##, and ##A## must not depend on ##t## and/or ##x##, because the transformation must be linear. So they can only be functions of the velocity ##v## between the frames.
The final step is indeed to get ##v## into the game. You have to express that frame ##\Sigma'## moves with velocity ##v## (in ##x##-direction) wrt. frame ##\Sigma##, i.e., the origin of ##\Sigma'##, which is described by ##x'=0## should lead to the trajectory in terms of the coordinates in ##\Sigma##, ##x=v t##, which in your coordinates reads
$$x'=0 \; \Rightarrow \; A x + B t=0 \; \Rightarrow \; x=-\frac{B}{A} t \; \Rightarrow \; v=-\frac{B}{A}.$$
That should lead to the correct result for the Lorentz boost.
Likes jk22
So the coefficients can depend only on ##v## but not ##t##.
Btw how do we know that they do not depend on the acceleration ? Are there experiments about this ?
What acceleration?
Not really, you can prove the invariance of the interval only by symmetry arguments, without any Lorentz transformation.
Or you can simply say the form invariance of the spacetime interval expressed in vector components wrt. different inertial (Minkowski) coordinates defines the corresponding transformations, leading to the Lorentz transformations.
It's a very similar argument that leads to the definition of rotations in Euclidean space as those transformations which leave the Euclidean distance invariant, when expressed in terms of Cartesian components. Another way to put it is that rotations map a right-handed Cartesian basis to another right-handed Cartesian basis.
Acceleration of what? The Lorentz transformations relate the behaviour of one set of inertial (i.e. non-accelerating) clocks and rulers to another such set. So nothing is accelerating.
You certainly can derive relations for accelerating clocks and rulers, but these are not the Lorentz transforms.
Don’t lose sight of the problem statement... you started with “derive the transformations between the coordinates used in two inertial frames” so you’re assuming no acceleration.
Likes Ibix
Related to Lorentz Transformation Derivation Question
1. What is the Lorentz Transformation?
The Lorentz Transformation is a mathematical equation that describes how the measurements of time and space change for an observer moving at a constant velocity relative to another observer.
2. Why is the Lorentz Transformation important?
The Lorentz Transformation is important because it is a fundamental concept in the theory of relativity, which is a cornerstone of modern physics. It helps us understand how time and space are relative to the observer's frame of reference and how this affects the laws of physics.
3. How is the Lorentz Transformation derived?
The Lorentz Transformation can be derived using the principles of special relativity and the postulates of the theory. It involves using mathematical equations to describe how time and space measurements change for an observer in motion.
4. What are the applications of the Lorentz Transformation?
The Lorentz Transformation is used in various fields of physics, such as particle physics, astrophysics, and electromagnetism. It is also used in practical applications, such as GPS technology and particle accelerators.
5. Is the Lorentz Transformation the same as the Galilean Transformation?
No, the Lorentz Transformation and the Galilean Transformation are different equations that describe the relationship between time and space measurements for observers in different frames of reference. The Lorentz Transformation is more accurate and takes into account the effects of relativity, while the Galilean Transformation is only applicable in classical mechanics.
