Lorentz Transformation Matrix: Tensor of Order 2?
In summary: GR in tensor notation is still GR.In summary, the Lorentz transformation matrix Λμν is a tensor of order two that can be interpreted as both a "passive" transformation and an "active" transformation. It is written in covariant formulation and can be viewed as a tensor in the context of GR. While it is possible to write the Lorentz transformation matrix in tensor notation, it does not necessarily mean that STR and GTR have been combined into one theory. Both theories can be formulated using tensors, but they are distinct theories in their own right.
Ben Geoffrey
Is the Lorentz transformation matrix Λμν a tensor of order two and does it transform like a tensor ?
Yes, but it's a little subtle. A transformation matrix simultaneously has two different interpretations:
  1. As a "passive" transformation: If you have a vector [itex]V[/itex] and its components in one coordinate system are [itex]V^\mu[/itex], then its components in a second coordinate system (related to the first through a Lorentz transformation) will be given by: [itex]V^\nu = \sum_\mu \Lambda_\mu^\nu V^\mu[/itex].
  2. As an "active" transformation: If [itex]V[/itex] is one vector, then we can defined a second, boosted vector [itex]V'[/itex] via: [itex](V')^\nu = \sum_\mu \Lambda_\mu^\nu V^\mu[/itex].
The distinction is a little subtle: In the first case, you have the same vector described in two different coordinate systems, and in the second case, you two different vectors described in the same coordinate system.
Viewed as an active transformation, [itex]\Lambda_\mu^\nu[/itex] is a tensor.
Thank you for that. I have another question. If its a tensor then can we say its written in covariant formulation ? Is there anything like a GTR formulation of STR ?
Sir my question is more along the lines of we write GTR in tensor notation right ? so if we write Lorentz transformation matrix in tensor notation does it mean we've combined STR and GTR and written it as one theory ?
STR and GTR are one theory. STR is just the special case of GTR for which spacetime is flat. This is true regardless of what notation you use. You can do GTR without using tensor notation (though it's a lot more tedious).
You can formulate any theory of physics (including Newtonian physics) as a tensor theory, as far as I know. You don't really change the theory when you change the mathematical formulation. SR in tensor notation is still SR.
FAQ: Lorentz Transformation Matrix: Tensor of Order 2?
What is the Lorentz Transformation Matrix?
The Lorentz Transformation Matrix is a mathematical tool used in the study of special relativity, which describes how measurements of space and time can vary for different observers moving at constant velocities relative to each other.
What is a tensor of order 2?
A tensor of order 2, also known as a second-order tensor, is a mathematical object that represents a linear transformation between two vectors. In the context of special relativity, the Lorentz Transformation Matrix is a second-order tensor that describes the transformation of coordinates and measurements between inertial frames of reference.
How is the Lorentz Transformation Matrix derived?
The Lorentz Transformation Matrix is derived using the principles of special relativity, specifically the equations for the Lorentz transformation of space and time coordinates. It can also be derived from the Lorentz boost formula, which relates the coordinates and velocities of an object in two different inertial frames of reference.
What are the properties of the Lorentz Transformation Matrix?
The Lorentz Transformation Matrix has the following properties:
  • It is a symmetric matrix.
  • It has a determinant of 1.
  • It is a unitary matrix, meaning its inverse is equal to its conjugate transpose.
  • It preserves the spacetime interval, which is a fundamental concept in special relativity.
How is the Lorentz Transformation Matrix used in physics?
The Lorentz Transformation Matrix is used in physics to describe how measurements of space and time are affected by relative motion between observers. It is a crucial tool in understanding the effects of special relativity, including time dilation, length contraction, and the relativity of simultaneity. It is also used in various other areas of physics, such as quantum mechanics and electromagnetism.
