Low Heat/Thermal Conductivity Electric Conductive Materials
Electric conductive materials with low thermal conductivity include certain stainless steel alloys, which can be advantageous due to their polished surfaces and internal grain structures. Multi-layer laminates can be effective if low thermal conduction and high electrical conduction are arranged perpendicularly. Thermoelectric materials are highlighted for applications requiring high electrical conductivity and low thermal conductivity, often involving heavy elements. Superconducting materials like NbTiN are noted for their low electrical losses in cryogenic applications. Alloys, such as copper-beryllium and copper-nickel, are generally preferred over pure metals for their lower thermal conductivity.
abdulbadii
TL;DR
What is an electric conductive material which is the least heat/thermal conductive?
What is/are the electric conductive material(s) which has/have the least heat/thermal conductive?
What materials have you looked at so far? What is the application? Will this be a thin film, a solid wire or bus bar, or a liquid maybe? The more details you can give, the better we will be able to help you.
Some stainless steel alloys used for cookware or kettles may surprise you. The polished surface, and the internal grain structure, can be used to advantage.
If the low thermal conduction, and the high electrical conduction, can be arranged to be perpendicular, then consider a multi-layer laminate.
What is the application ?
Try searching thermoelectric cooling. From one of the hits:
Requirements for thermoelectric materials:
High electrical conductivity (to reduce electrical resistance, a source of waste heat);
Low thermal conductivity (so that heat doesn't come back from the hot side to the cool side); this usually translates to heavy elements
Sounds like what you are looking for.
Likes Lord Jestocost
Superconducting materials (both conventional and HTS), this is what is used in cryogenic applications. E.g. NbTiN is used both for DC and RF applications and that the electrical losses are very low is of course a bonus.
As has already been mentioned stainless steal is also an option, but might be a bit too lossy for many applications.
Generally speaking, alloys have lower thermal conductivity than "pure" metals and are therefore often used. copper-beryllium and copper-nickel would be two widely used examples.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
10K
