Low-noise Amplifier for a sensitive radio receiver
  • Thread starter Thread starter WonderNomad
    Transistor
When designing a low-noise amplifier (LNA) for a sensitive radio receiver, key noise sources to consider include thermal noise, shot noise, and flicker noise at the transistor level. Different LNA topologies, such as common-source, common-gate, and common-drain with inductive degeneration, significantly affect the overall noise figure and gain. Trade-offs in optimizing these parameters involve balancing noise performance with gain and stability. The discussion also highlights the importance of isolating radio circuits on PCBAs to prevent noise coupling, particularly when digital electronics are present. Understanding receiver sensitivity and employing techniques like "Star Grounding" can enhance the design's effectiveness.
WonderNomad
I'm designing a low-noise amplifier (LNA) for a sensitive radio receiver. What are the key noise sources I need to consider at the transistor level (e.g., thermal noise, shot noise, flicker noise)? How do different LNA topologies (e.g., common-source, common-gate, common-drain with inductive degeneration) impact the overall noise figure and gain? What are the trade-offs involved in optimizing these parameters?
In addition to the buy-vs-build question asked by @Baluncore -- do you have experience designing PCBAs with sensitive radio circuits? What is the application? Will there be digital electronics on the same PCBA? It is *extremely* important to isolate different parts of radio circuits on PCBAs to avoid coupling of noise between sections via shared impedances (like power supply and ground impedance). Are you familiar with techniques such as "Star Grounding" to achieve such isolation?
Also, what level of receiver sensitivity (in dBm) are you shooting for? https://www.repeater-builder.com/tech-info/measuring-sensitivity/measuring-sensitivity.html
I was wondering why you have chosen inductive degeneration for common source operation?
It’s all about matching the source impedance to the transistor input impedance that optimizes its noise figure. Pay attention to the Smith chart noise figure circles on the device data sheet.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
