Low RPM high Torque Motor with enough power to rotate 30 pounds?
For an engineering project requiring a motor to rotate a 30-pound base at 1 to 6 rotations per hour, a winch motor is recommended due to its capability for low-speed operation. These motors are affordable, typically under $100, and can be powered by a small car battery or an AC/DC converter for convenience. The low current load makes it feasible to use a simple power source without significant complications. The discussion emphasizes the availability and efficiency of winch motors for such tasks. Overall, this setup should effectively meet the project's requirements.
kakashi1027
Hi, I'm working on an engineering project and I need to get a 30pound base to rotate at speeds between 6 rotations per hour and possibly 1 rotation per hour.
Does anyone know where to get such a motor, or if it is even possible?
Can anyone think of a better more efficient way of doing this task?
Thanks!
30 lbs? That's all?
1-6 rph? That's VERY slow.
Not sure why there is any problem.
A "winch" motor comes to mind, as it can be very slow.
Cheap and widely available for less than $100.
for the winch motor, what kind of power source do I attach it to?
DC. Car battery.
In your case, the load is so low that a very small car battery would work just fine.
Edit: Of course, with such a low current load, a simple AC/DC converter rated to your specs will work as well, with the benifit of just plugging it into your AC wall outlet.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
