MHB LU decomposition: Total pivoting
  • Thread starter Thread starter mathmari
    Decomposition
The discussion focuses on determining the LU decomposition of a matrix with total pivoting, specifically for the matrix A. The participants detail the steps taken to perform row and column exchanges to achieve the upper triangular matrix U and discuss the definitions of permutation matrices P and P_i. There is confusion regarding the correct formulation of the matrix L and its relationship with the permutation matrices and inverses of the Gaussian elimination steps. Ultimately, it is clarified that the relationship should be expressed as LU = PAQ, where P and Q account for the row and column permutations, respectively. The final consensus is that the calculations for L are correct, and the relationship between the matrices is properly established.
mathmari
MHB
Hey! :o
I want to determine the LU decomposition of
$A=\begin{pmatrix}0 & 2 & 1\\1 & 10 & 1 \\1 & 1 & 1\end{pmatrix}$ with total pivoting. I have done the following:
The biggest element of the whole matrix is $10$, so we exchange the first two rows and the first two columns and then we get $\begin{pmatrix}10 & 1 & 1 \\2 & 0 & 1\\1 & 1 & 1\end{pmatrix}$.
Applying now the Gauss algorithm we get $\begin{pmatrix}10 & 1 & 1 \\0 & -\frac{1}{5} & \frac{4}{5}\\0 & \frac{9}{10} & \frac{9}{10}\end{pmatrix}$.
The biggest element of the submatrix is $\frac{9}{10}$ and so we exchange the last two rows and get: $\begin{pmatrix}10 & 1 & 1 \\ 0 & \frac{9}{10} & \frac{9}{10} \\ 0 & -\frac{1}{5} & \frac{4}{5} \end{pmatrix}$. Now we apply the Gauss algorithm and get: $\begin{pmatrix}10 & 1 & 1 \\ 0 & \frac{9}{10} & \frac{9}{10} \\ 0 & 0 & 1 \end{pmatrix}$.
The matrix $U$ is the resulting matrix, $U=\begin{pmatrix}10 & 1 & 1 \\ 0 & \frac{9}{10} & \frac{9}{10} \\ 0 & 0 & 1 \end{pmatrix}$.
The matrix $L$ is $L=P\cdot P_0\cdot G_1^{-1}\cdot P_1\cdot G_2^{-1}$, or not? (Wondering)
The matrices $G_i^{-1}$ are defined as:
$$G_1^{-1}=\begin{pmatrix}1 & 0 & 0 \\\frac{2}{10} & 1 & 0\\\frac{1}{10} & 0 & 1\end{pmatrix} \ \text{ and } \ G_2^{-1}=\begin{pmatrix}1 & 0 & 0 \\0 & 1 & 0\\0 & -\frac{2}{9} & 1\end{pmatrix}$$ or not? (Wondering)
Are the matrices $P_i$ defined as follows?
$$P_0=\begin{pmatrix}1 & 0 & 0 \\0 & 1 & 0\\0 & 0 & 1\end{pmatrix}$$ since this describes the step at which we exchanged the first two rows and the first two columns. (Wondering)
$$P_1=\begin{pmatrix}1 & 0 & 0 \\0 & 0 & 1\\0 & 1 & 0\end{pmatrix}$$ since this describes the step at which we exchanged the two last rows. (Wondering) If these are correct, it doesn't hold that $LU=PA$, does it? (Wondering)
Mathematics news on Phys.org
Hey mathmari!
It should be clear that
cannot be correct. It is the identity matrix, isn't it? (Worried)
Let's define instead:
$$P_0=\begin{pmatrix}0 & 1 & 0 \\1 & 0 & 0\\0 & 0 & 1\end{pmatrix}$$
This is the matrix that swaps either 2 rows or 2 columns, isn't it?
And it's its own inverse. That is, $P_0^{-1}=P_0$.
Swapping 2 rows is a permutation on the left.
However, swapping 2 columns is a permutation on the right.
So after those 2 permutations we have $P_0 A P_0$. (Thinking)
Shouldn't it be $LU=PAQ$, where $P$ reorders the rows of $A$ and $Q$ reorders the columns of $A$? (Wondering)
I don't think so. We have:
$$R = G_2 \cdot P_1 \cdot G_1 \cdot P_0 \cdot A \cdot P_0$$
From this we have to deduce $L$ such that:
$$LR = PAQ$$
Don't we? (Wondering)
We have $R=\begin{pmatrix}10 & 1 & 1 \\ 0 & \frac{9}{10} & \frac{9}{10} \\ 0 & 0 & 1 \end{pmatrix}$.
Since $R = G_2 \cdot P_1 \cdot G_1 \cdot P_0 \cdot A \cdot P_0$ we get that $$L\cdot G_2 \cdot P_1 \cdot G_1 \cdot P_0 \cdot A \cdot P_0=P\cdot A\cdot P_0 \Rightarrow L =P\cdot P_0^{-1}\cdot G_1^{-1}\cdot P_1^{-1}\cdot G_2^{-1} \Rightarrow L=P_1\cdot G_1^{-1}\cdot P_1\cdot G_2^{-1}$$
We have the matrices $$G_1^{-1}=\begin{pmatrix}1 & 0 & 0 \\\frac{2}{10} & 1 & 0\\\frac{1}{10} & 0 & 1\end{pmatrix} \ \text{ and } \ G_2^{-1}=\begin{pmatrix}1 & 0 & 0 \\0 & 1 & 0\\0 & -\frac{2}{9} & 1\end{pmatrix}$$ We also have the matrices $$P_0=\begin{pmatrix}0 & 1 & 0 \\1 & 0 & 0\\0 & 0 & 1\end{pmatrix} \ \text{ and } \ P_1=\begin{pmatrix}1 & 0 & 0 \\0 & 0 & 1\\0 & 1 & 0\end{pmatrix}$$
So we get $$L=\begin{pmatrix}1 & 0 & 0 \\0 & 0 & 1\\0 & 1 & 0\end{pmatrix}\begin{pmatrix}1 & 0 & 0 \\\frac{2}{10} & 1 & 0\\\frac{1}{10} & 0 & 1\end{pmatrix}\begin{pmatrix}1 & 0 & 0 \\0 & 0 & 1\\0 & 1 & 0\end{pmatrix}\begin{pmatrix}1 & 0 & 0 \\0 & 1 & 0\\0 & -\frac{2}{9} & 1\end{pmatrix}=\begin{pmatrix}1 & 0 & 0 \\ \frac{1}{10} & 1 & 0 \\ \frac{1}{5} & -\frac{2}{9} & 1\end{pmatrix}$$
Is this correct? (Wondering)
How did you get $P\cdot P_0^{-1}=P_1$ ?
I think that the $P$ we will get, will be incorrect. (Worried)
Is this correct?
Yes. (Nod)
Do we not have $P=P_1P_0 \Rightarrow PP_0^{-1}=P_1$ ? (Wondering)
Ah yes, $P$ has to be whatever row permutation it takes to ensure that $L$ is a lower triangular matrix.
We have:
$$L =P\cdot P_0^{-1}\cdot G_1^{-1}\cdot P_1^{-1}\cdot G_2^{-1}$$
And $G_1^{-1}$ and $G_2^{-1}$ are lower triangular.
Since $P_1\cdot G_1^{-1}\cdot P_1^{-1}$ is a conjugation, it is lower triangular as well.
That is, we swap 2 rows and we also swap the corresponding 2 columns, so that the triangular form is retained. (Nerd)
So we can indeed pick $\smash{P\cdot P_0^{-1}=P_1}$.
I must have made a calculation mistake earlier. (Blush)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
