LW Infrared Trasmissivity of Air
  • Thread starter Thread starter ALm865
    Air Infrared
The discussion focuses on finding an equation or table for the transmissivity of air in the 7.5-13.5 µm region, emphasizing the need for an understanding of the attenuation coefficient, which consists of scattering and absorption components. It highlights that while scattering can often be ignored in air, absorption is related to emissivity due to Kirchhoff's Law. The user expresses frustration with the complexity of existing software like MODTRAN, seeking simpler alternatives for calculating transmissivity under varying conditions such as humidity and gas concentrations. Suggestions for resources and tools are provided, but the user is specifically looking for free options that are applicable at sea level. The conversation underscores the challenge of obtaining accurate atmospheric transmissivity data without resorting to complex or costly software solutions.
ALm865
Hi All,
I am after an equation/table of that describes the Transmissivity of Air in the 7.5-13.5um region.
I understand that Beer–Lambert's law says that the relative intensities of a beam in a medium varies exponentially with distance and particle density, but you need to know the attenuation coefficient use those equations.
The attenuation coefficient appears to be made up of a scattering and absorption component. I've read (correct me if I'm wrong) that the scattering component can be ignored in air and the absorption is then equal to emissivity due to Kirchhoff's Law.
I also understand that emissivity changes at different wavelengths and may have a complex component (which I think I can ignore because I think it relates to scattering/dispersion?)
How would I go about this problem? There are computer packages such as MODTRAN but they seem way too complex for what I am after and I haven't the faintest idea on how to use them.
All I'm after is an equation, or a look-up table to calculate the Transmissivity of air under certain conditions (i.e. Humidity, Distance, Air Temperature/Density)
In addition, how do I account for relative humidity, and increased percentages of other gasses such as CO2?
Science news on Phys.org
ALm865 said:
<snip>There are computer packages such as MODTRAN but they seem way too complex for what I am after and I haven't the faintest idea on how to use them.
You do realize that you are describing MODTRAN/LOTRAN/HITRAN?
In any case, google is your friend:
http://www.astro.virginia.edu/~mfs4n/ir/atmtrans.html
http://books.google.com/books/about/LWIR_Long_Wavelentth_Infra_Red_Atmospher.html?id=Iaa7tgAACAAJ
http://gs.flir.com/uploads/file/tech-notes/tech note13 - ir spectral bands.pdf
Ah Damn, i was hoping the problem would be more simple than diving into something MODTRAN. I was hoping since I was choosing a specific wavelength I could get away with a few constants.
I've been looking into FLIR's GEV Demo code here: http://support.flir.com/SwDownload/Assets/ThermoVision/PvSample.zip and they do compensate for humidity and distance in their temperature calculations (see PvSimpleUISampleDlg.cpp and functions doCalcAtmTao, doCalcK2, and doCalcK1) but they use what looks to be a polynomial to describe relative humidity. It looks to me like a curve of best fit that they've calculated somehow (probably using MODTRAN or equivalent).
Can anyone suggest any free and easy to use alternatives to MODTRAN? I've gone through a few on the list but I haven't got the faintest idea on whether they are only relevant for satellites or also can be used at sea level? A lot of them talk about typical atmosphere from satellites to the ground and include factors such as cloud cover, and gasses. I'm only after sea level calcs. http://en.wikipedia.org/wiki/List_of_atmospheric_radiative_transfer_codes
Thanks in advance
Also, the reason I'm trying to find an alternative to MODTRAN is because you have to buy a license to use MODTRAN.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
