Magentic Fields and Force Exerted
  • Thread starter Thread starter Theudius
    Fields Force
The discussion centers on understanding why the force exerted by a magnetic field on a current-carrying wire is zero in a specific scenario. The equation F = BIL sin(x) is applied, revealing that the net flow of current is zero due to equal and opposite currents in the wire segments. Each segment experiences equal forces in opposite directions, resulting in a net force of zero. The participants clarify that the sine values for the angles involved confirm this cancellation of forces. Ultimately, the conclusion is that the resultant force is zero due to the symmetry of the current directions.
Theudius
2. Homework Equations [/B]
F = BIL sin(x)
This isn't homework its a practice question so I have looked at the answer and its 0N however I do not understand why it is 0N. I have tried resolving the magnetic flux density so its perpendicular to the flux and I get my answer to be "B".
Thanks.
At any cm section of the wire pair what is the net flow of current? Or you could take each part of the pair separately and note the directions of the forces and strength and note the resultant.
So the net flow of current is 0A as shown by the diagram there are two arrows in the opposite direction of magnitude 5.0A?
That is what the author intended you to note. What about the force on each segment ( incoming and outgoing)?
Through the equation F = BIL sin(x) since the current is the same on each side, the force incoming is the same as the force outgoing hence the resultant force will be zero?
Yes and you should also say they are in opposite directions . sin(30°) = - sin(150°)
Likes Theudius
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
