Magnesium bisglycinate + citric acid = ?
Mixing magnesium bisglycinate with citric acid in water results in a chemical reaction that can produce magnesium citrate, which is known for its laxative effects. Magnesium bisglycinate is primarily used as a supplement for individuals with low magnesium levels and can also serve as an antacid. The interaction between these compounds can lead to unintended consequences, such as converting a supplement into a laxative. In solution, magnesium remains in the form of Mg2+, and the equilibrium involves glycine and magnesium citrate. Even in the presence of strong acids, magnesium bisglycinate would convert to glycine and magnesium sulfate, but the magnesium ion itself does not change form. Caution is advised when mixing supplements and other chemicals due to potential interactions.
ivannovak
Hello,
I have a question or two that I need help with:
What happens when you put magnesium bisglycinate and citric acid into water solution?
Does magnesium change form here?
Kind regards,
IN
Chemistry news on Phys.org
You can get magnesium citrate (citrate of magnesia, a laxative)
Magnesium bisglynate is used as a supplement for patients with low serum magnesium levels, and sometimes as an antacid to treat acid burps for example.
The reason I mention this is that you should not fool around with mixing supplements and other chemicals because they can interact. This example turns a supplement into a laxative. Not a good idea.
Likes berkeman and BillTre
Well technically, magnesium citrate is also a supplement with laxative side effects
Magnesium bisglycinate is presumably a weak base (pKa similar to other carboxylates). So in solution, you would get an equilibrium between glycine (conjugate acid of glycinate) and magnesium citrate.
Magnesium exists as Mg2+ and it wouldn't change. Even in the presence of a strong acid such as H2SO4, you would just get a full conversion of magnesium bisglycinate to glycine and MgSO4.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
