Magnetic Acceleration: Calculate Force & Distance
To calculate the acceleration of a metal object towards a magnet, one can use the formula a = f/m, where f is the magnetic force and m is the object's mass. The magnetic force varies with distance, increasing as the object approaches the magnet, which affects the acceleration at different points in space. To determine the magnetic force at a specific distance, additional calculations or formulas related to magnetic fields and distances are required. The discussion highlights the need for clarity on how to calculate magnetic force in relation to distance. Understanding these principles is essential for accurately predicting the object's behavior in a magnetic field.
moni94
Hi. If I have a metal object such as a metal marble and I know its weight and distance from a certain magnet, which I know the magnetic force of, can I find the acceleration of the object's attraction towards the magnet?
Yes, you can calculate the acceleration of the object due to magnetic force(a=f/m). The magnetic force increase as the object moves closer to the magnet which means the magnetic force is the property of space provided by the magnet and is different at different point in space and in turn the acceleration of the object is different in different points in space The acceleration increase as the object approaches the magnet.
Yes, but how do I calculate the magnetic force from a particular distance?
Anyone? How do I calculate magnetic force vs distance?
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
