Magnetic field at origin because of 3 wires
To determine the magnetic field at the origin due to three wires, the relevant equation for straight wires, B = μ₀I/(2πr), is not applicable since the wires are not infinitely long. The discussion suggests using the Biot-Savart law, which accounts for finite lengths of wires, as a more suitable approach. Participants highlight the need to consider the geometry of the setup, particularly the distances involved, to accurately calculate the magnetic field contributions from each wire. The importance of symmetry in applying Ampere's law is also noted, although it may not be straightforward in this scenario. Ultimately, the Biot-Savart law is recommended for this calculation.
irishbob
Determine the magnetic field (in terms of I, a, and d) at the origin due to the current loop shown in Figure P30.14. (Use mu_0 for µ0, pi for π, a, d, and I as necessary.)
http://www.webassign.net/pse/pse6_p30-14.gif
B=mu_0(I)/(2pi*r) for straight lines
http://www.webassign.net/cgi-bin/symimage.cgi?expr=2%28%28mu_0%29I%29%2F%282pi%2Asqrt%28d^2%2Ba^2%29%29-%28mu_0%29I%2F%282pi%2Ad%29&size=4
What I did was, since the ones on the left and right are equal, and in the same direction, I found the distance between the two wires (the square root in the equation), plugged that in for r, and multiplied it by 2. For the horizontal wire, I just plugged d into r. This is in the opposite direction by right hand rule, so I made it negative.
What am I doing wrong? Help!
That equation only works when the wires can be considered infinitely long. That is not the case here.
Do you have any other formulas that deal the magnetic field due to a wire of any length?
Ah.
Well there's the B-S law
B=(μ_0*I)/(4pi)*∫(d*(l x r(hat))/r^2
and
Ampere's law:
∫(enclosed) B·dl=μ_0 I(enclosed)
and for Ampere's it has to be highly symmetrical with constant field for us to use it easily.
I still don't know which to use. It seems like it would be difficult to use Ampere's law because the field isn't uniform. Or is it? I'm not so great at this :P
The Biot-Savart law is the one to use.
Thanks! :D
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
