Magnetic field due to the current flowing in a bent wire
The discussion focuses on calculating the magnetic field generated by a bent wire along the x-axis, emphasizing that the parallel section of the wire does not contribute to the magnetic field. The main challenge is defining the integral components, particularly the vector representation of the wire segment. Participants suggest considering simple angles, such as a 90-degree bend, to simplify the analysis. They recommend visualizing the magnetic field as if the wire were entirely at the new angle to better understand the situation. Understanding these concepts is crucial for progressing in the calculations.
Elder1994
A very thin linear conductor, which carries the current 𝐼, bends an angle 𝛼 with respect to its initial direction at some given point, as shown in the figure. Find the magnetic field 𝑩 along the line of the initial run.
$$\mathbf {B} = \int {\frac {dS \otimes r} {r^3}}$$
Hello, in this problem I'm supposed to calculate de magnetic field due to a bent wire at any point of the x-axis after the bending of the wires. It is obvious that the part of the wire that is parallel to the x-axis makes no contribution to the field so we can focus on the other part of the wire. Here I'm having some problems trying to define all the parts of the integral, I now that the dS = dx i + dy j, but I can not figure out how $$\mathbf {r}$$ looks like.
download
Helps to think about how the physics described by the equations works.
Can you sketch the field?
Taking the x-axis pointing in the direction of the current before the bend ... what happens is the current changes direction to an angle to the x axis.
So did you have a think about some easy angles ... ie. what if the bend was 90 degrees?
So what would the field along the x-axis look like if the wire was not bent at all, but, instead, was entirely at that angle?
Once you understand the situation, you'll find it easier to decide how to go forward.
Likes Delta2
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
