Magnetic Fields and Maximum Current
The discussion centers on calculating the maximum current a wire can carry while measuring the Earth's magnetic field at a distance of 0.60 m. The initial calculation using the formula B = (4π*10^-7)I / (2πR) resulted in an excessively high value of 135 A. The error stemmed from misunderstanding the impact of the +/- 1% measurement accuracy on the magnetic field value. By adjusting the magnetic field to account for the 1% variation before recalculating, the correct current value was achieved. This clarification emphasizes the importance of considering measurement tolerances in experimental setups.
Mehta29
Hey guys I'm new here and needless to say I am completely lost...
well here is the problem...
What is the maximum current that a wire can carry if an experimenter is performing an experiment 0.60 m away that deals with the Earth's magnetic field (4.5*10-5 T), which she wishes to measure to +/- 1 percent?
i thought I could just plug the #'s given into
B = (4pi*10^-7)I / (2(pi)R)
and i ended up with 135 A...which seemed muuuuuuuuch too high...and assumably was wrong...
(4.5*10^-5) = (4pi*10^-7)I / 2(pi)(.6??)
It would be greatly appreciated if i could get this help tonight...but I just want to understand what I'm doing wrong for the most part...
well i found the error of my ways...
the whole +/- 1% threw me off...
i get the right answer if i multiply by the magnetic field by 1% and then re-plug everything in...
hopefully this helps someone in the future...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
