Magnetism, difference between B, H and M
lys04
112
What's the difference between B, H and M in magnetism?
B, H, M
As the homework statement suggests
What research have you done? What does your textbook say?
B, H, M is a juxtaposition of symbols not a "relevant equation."
"As the homework statement suggests" is not a credible attempt at answering the question.
Please try harder.
  • Love
Likes Vanadium 50 and PeterDonis
You must also show your work and where you got stuck.
FAQ: Magnetism, difference between B, H and M
What is the difference between B, H, and M in magnetism?
B, H, and M represent different magnetic fields and magnetization in materials. B, or the magnetic flux density, measures the total magnetic field, including contributions from free currents and bound currents. H, or the magnetic field strength, measures the magnetic field produced by free currents in a material. M, or the magnetization, indicates the density of magnetic moments in a material, showing how much a material is magnetized in response to an external magnetic field.
How are B and H related in a material?
The relationship between B and H in a material is described by the equation B = μH, where μ is the permeability of the material. This equation indicates that B depends on both the magnetic field strength H and the material's ability to conduct magnetic lines of force, represented by its permeability.
What role does magnetization (M) play in magnetism?
Magnetization (M) plays a crucial role in determining how a material responds to an external magnetic field. It represents the extent to which a material becomes magnetized when exposed to a magnetic field and contributes to the overall magnetic field within the material. The magnetization is a vector quantity that can vary with the applied field strength and the material's properties.
How do B, H, and M behave in different types of materials?
In different types of materials, B, H, and M behave differently. In free space, B and H are directly proportional. In linear magnetic materials, B and H are related through a constant permeability. In ferromagnetic materials, M can be significantly large, leading to complex hysteresis behavior, where the relationship between B and H is nonlinear and path-dependent due to the material's magnetic history.
Can you explain the concept of magnetic susceptibility?
Magnetic susceptibility (χ) is a dimensionless quantity that indicates how susceptible a material is to becoming magnetized in response to an applied magnetic field. It relates the magnetization (M) to the magnetic field strength (H) through the equation M = χH. Materials can be classified based on their susceptibility: diamagnetic materials have negative susceptibility, paramagnetic materials have positive but low susceptibility, and ferromagnetic materials have high positive susceptibility, indicating strong magnetization effects.
