Magnetix flux density & Zero scalar potential
Magnetic flux density is confirmed to be perpendicular to external boundaries where zero magnetic scalar potential is imposed. This relationship is supported by the properties of fields that satisfy Laplace's equation, where equipotential lines are orthogonal to the gradient. The discussion highlights the importance of understanding the mathematical principles behind magnetic fields. The interaction between magnetic flux density and scalar potential is clarified through these equations. Overall, the conversation emphasizes the foundational concepts in electromagnetic theory.
baggiano
Hi
Can anybody tell how I can prove that the magnetic flux density is perpendicular to external boundaries with imposed zero magnetic scalar potential?
Thanks
Bag
I believe that for any field that satisfies Laplace's equation (divergence of a gradient), the equipotential lines (curl of the gradient) are orthogonal to the gradient. Is this what you mean?
Bob S
Thanks for the reply and for your explanation. That precisely explains what I meant. Thanks again.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
