Magnitude and direction of acceleration
The discussion focuses on calculating the magnitude and direction of acceleration while sliding towards home plate after reaching a speed of 5.9 m/s. The calculated acceleration is 5.36 m/s², but clarification is needed on its direction, which could be toward home plate or third base. To determine the distance slid, participants discuss using the equation d = vt + 1/2at², acknowledging the need to consider the final velocity as zero. Alternative methods, such as using the relationship V² = 2ax, are also suggested for calculating distance. Understanding the relationships between distance, time, and acceleration is emphasized as crucial for solving the problem effectively.
bumblebee
1. You are going toward home plate at speed of 5.9 m/s when you hit the dirt. You slide for 1.1 s just reaching the plate as you stop.
a)What is the magnitude and direction of your acceleration?
b) How far did you slide?
I got 5.36 m/s^2 for the acceleration. Not sure if I did this right.
Welcome to PF.
That looks OK for magnitude. Which direction was the acceleration? Toward the plate or toward 3rd base?
Now how far was the slide. Do you have an equation that would give you the distance if you know the acceleration and time?
Thanks, LowlyPion.
Is it d=vt + 1/2at^2?
I'm getting all these equations confused.
bumblebee said:
Thanks, LowlyPion.
That works as long as you realize that you are coming to a stop, so velocity will be 0.
Alternatively since you also know velocity you could use the relationship that
V2 = 2 a x
That should yield the same result.
It's important to understand that the relationships between distance, time, acceleration can be reworked in a number of ways to express things in terms that you may have directly to find what you need.
This link may provide you with a list of the equations as a brief reference:
https://www.physicsforums.com/showpost.php?p=905663&postcount=2
Thanks! This helps!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
