Magnitude and Direction of Magnetic Field
An electron moving northward in a magnetic field experiences an upward force of 7.2 x 10^-13 N. The relationship between force, charge, velocity, and magnetic field strength is described by the equation F = qvB, indicating that the magnetic field must be perpendicular to the direction of the force. The magnetic field's direction is determined to be horizontal, and since the electron has a negative charge, the field direction is opposite to the assumed positive direction. This leads to the conclusion that the magnetic field points eastward. Understanding these principles is essential for solving related physics problems.
thermocleanse
An electron experiences the greatest force as it travels 2.9 x 10^6 ms in a magnetic field when it is moving northward. The force is upward and of magnitude 7.2 x 10^-13 N. What are the magnitude and direction of the magnetic field?
I don't even know how to get a diagram going for this. Anything would be helpful. Thank you.
What is the force exerted by a magnetic field of strength B, on a charge Q, moving at a velocity v?
F=?
When you get that it becomes simple algebra.
If the electron is moving northwards, what direction should the field be pointing?
I'm using F(max) = qvB because it seems that it's 90 degrees. The field should be 90 degrees relative to the upward force, so the field is perpendicular, or horizontal, right?
Also, because of the charge on the electron, i get a negative answer (in Tesla). does this mean that i indicate the negative charge as "eastward?"
please see attached. thank you!
I think if it is negative then your field should be pointing in the opposite direction that you took as the +ve direction.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
