Magnitude of the average force exerted by ground on a ball.
The discussion revolves around calculating the average force exerted by the ground on a basketball after it bounces. The basketball, with a mass of 0.625 kg and an initial speed of 3.30 m/s, loses half of its kinetic energy upon bouncing, resulting in a post-bounce speed of 2.33 m/s. Participants highlight the importance of considering gravitational force when calculating the change in velocity (Δv) for the average force equation. The correct approach involves recognizing that the initial and final velocities have opposite directions, which affects the calculation of net force. Understanding these dynamics is crucial for accurately determining the average force, which was initially miscalculated.
NinjaChachi
Just before hitting the ground, a partially inflated 0.625kg basketball has a speed of 3.30m/s. Then it loses half of its kinetic energy as it bounces. (A)What is the ball's speed immediately after it bounces?(B) If the ball is in contact with the ground for 9.25ms, what is the magnitude of the average force exerted by the ground on the ball?
None of these are positive but:
KE=.5mv^2
Fav=m(Δv)/(Δt)
I found part A I believe. I just found the initial KE in that being KE=.5(.625)(3.30)^2 and got KE0=3.4
then it loses half so KEf=1.7 so to find the velocity I set up 1.7=.5(.625)v^2 and found the final velocity to be 2.33m/s.
I am quite confused on part B. I have tried m(Δv)/(Δt) to find the Fav but didn't get the right answer (381N). What do I do?
Good.
What did you use for Δv? Did you take gravity into account?
Doc Al said:
Good.What did you use for Δv? Did you take gravity into account?
No I didn't use gravity. I just used 3.3-2.33 and tried 2.33-3.3. How would I take gravity into account?
Try that again. Realize that the final and initial velocities have different directions.
Realize that m(Δv)/(Δt) will give you the average net force. What forces act on the ball during the collision with the ground?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
