Magnitude of the electric field?
Eliasm
Charge of uniform density 4.0nC / m is distributed along the x axis from x = - 2.0m to x = + 3.0 * m . What is the magnitude of the electric field at the point x = +5.0 m on the X axis?
Electric field
Zzzz
According to PF rules, you need to show some effort and attempt at a solution before receiving help. Also, "Electric field" is not an equation, it is a vector.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
