Magnitude of the non-coulomb electric field around a solenoid.
The discussion centers on calculating the magnitude of the non-Coulomb electric field around a solenoid with a changing magnetic field. The initial calculations for the electromotive force (emf) yielded 251.3 volts, but confusion arose regarding the application of the emf equation from the perspective of the metal ring surrounding the solenoid. Participants clarified that the emf should be calculated based on the ring's area, leading to a revised emf of 3.62 volts. The subsequent calculation for the electric field resulted in 2.40 V/m. The thread emphasizes the importance of correctly identifying the area relevant to the emf calculation in such problems.
Pepjag
A metal ring of radius r = 24 cm surrounds a
solenoid of radius R = 2 cm and 10000 turns.
The magnetic field inside the solenoid changes from 5 T to 3 T in
0.1 s. Find the magnitude of the non-Coulomb
electric field along the ring.
Answer in units of V/m
emf = -N*d(flux)/dt = -N*db/dt*A
emf = integral of E*dl
Ok, so i pretty much just plugged in numbers. for the emf:
emf = -10000*(3-5)/0.1*pi*0.02^2 = 251.3 volts.
For the electric field:
E = emf/L = 251.3/2*pi*0.24 = 166.7 V/m
Unfortunately, the computer keeps saying I'm wrong. Am I really doing something wrong? This seemed pretty straight forward.
You're looking at the emf induced in the metal ring. How many turns of wire does a metal ring have?
Wait, so you have to use the emf equation from the ring's perspective?
emf = (3-5)/0.1*pi*0.24^2 = 3.62 volts.
E = emf/L = 251.3/2*pi*0.24 = 2.40 V/m
Or do I still use the solenoid's area for the emf?
I have until 11:30 ct to finish this one problem, can anyone please give input.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
