MHB Make x the subject of 2x/5-3b/4=x+5
  • Thread starter Thread starter blackfriars
To rearrange the equation 2x/5 - 3b/4 = x + 5 and make x the subject, the fractions can be eliminated by multiplying both sides by 20, the least common multiple of the denominators. This results in the equation 8x - 15b = 20x + 100. Rearranging gives -15b - 100 = 12x, which simplifies to x = -(15b + 100)/12. The discussion highlights the importance of properly handling terms when moving them across the equation, as mistakes can lead to incorrect conclusions about the value of x. Understanding these steps is crucial for solving similar algebraic equations effectively.
blackfriars
hi to all
looking for some help to rearrange a formula to make x the subject
2x/5-3b/4=x+5
i moved +5 to the left and it became -5
i thought the negative 5 would cancel the denominator 5
this is what i thought i could do
2x-3b/4=x
-2x -2x
-3b/4 =-x
multiply both sides by -1 and the result i thought should be
3b/4=x
thanks in adv
Mathematics news on Phys.org
Are you a student attending math classes?
Yes i am
$$\frac{2x}{5} - \frac{3b}{4}=x+5$$
To clear fractions, multiply both sides of the equation by $20$, the $\text{lcm}$ of $5$ and $4$:
$$8x-15b=20x+100$$
Rearrange so $x$ is on its own on one side of the equation:
$$-15b-100=20x-8x$$
Simplify:
$$-15b-100=12x$$
Divide through by $12$:
$$x=-\frac{15b+100}{12}$$
Thanks for that all i can do is learn
Cheers
Make up a simple case:
x/5 = 5 : evident that x = 25, right?
Now, move the 5 as you did:
x/5 - 5 = 0 : ok?
Cancel the denominator with the -5:
x = 0
BUT x = 25 : convinced?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
