Making a solar cell phone charger
A user is repurposing a small solar panel (8W, 17V) to create a solar charger for phones and USB devices. They successfully assembled a 5VDC regulator kit and are considering connecting multiple USB ports. Concerns were raised about the current output, with calculations indicating a maximum output of 470 mA, which is significantly lower than the 2A output of standard chargers. It was suggested to consider using a battery pack for more versatility and to attach a heatsink to the regulator due to heat generation. The setup is functioning well for charging a portable phone charger.
eddie90
Good day everyone,
So I have a spare solar panel that has been laying around and I want to put it to use. Its a small panel, about 8"X12". The specs read 8 Watts and 17 Volts
I was thinking of maybe making a solar charger for phones and other 5VDC USB devices.
I bought a 5VDC regulator kit, soldered it together and got it to work with the panel
This is the kit:
http://www.superdroidrobots.com/shop/item.aspx/5v-regulator-board-kit/508/
Next I want to hook the output up to a set of maybe 2 or 4 USB ports. I can get these off an old computer or other device.
My question is, how do I know how much current this thing will output at 5VDC?
I know my factory cell phone charger outputs 2000ma or 2 amps.
How do I know that this setup will not output more than that and damage the device being charged.
Or is this setup even strong enough to go up to 2 amps?
Is there a way to test for this?
Thank you and sorry for the long post
-Eddie
Borg said:
There are a bunch of designs for this at this site - http://www.instructables.com/howto/solar+panel+charger/
With respect to the power requirements, some of them use the solar panel to charge a battery pack - http://www.instructables.com/id/Solar-USB-Charger-20-21/
I had not thought about charging a battery pack. That might be better, it is not limited to providing power only while under the sun.
I will look at these examples in detail tonight when I get home
Thank you!
The specifications for the PV is; 17V, 8W. The current will be ( 8W / 17V ) = 0.47A.
The regulator is a linear regulator so Iin = Iout.
The maximum current out will therefore be 470 mA.
The voltage drop across the regulator will be 17Vin – 5Vout = 12V
The regulator will therefore dissipate power ( 12V * 0.47A ) = 5.64W
Maybe you should consider a heatsink if the regulator gets hot.
The regulator chip did did begin to get a little hot so I did attach a small heatsink to it.
I am using it to charge a portable phone charger that itself is charged with 5V
Seems to work just fine now.
Thank you!
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
