A Margules' Power Series Formula: Deriving Coefficients
Margules proposed a power series formula to describe the activity composition variation in binary systems, represented by lnγ1 and lnγ2 equations. The derivation involves applying the Gibbs-Duhem equation while neglecting higher-order coefficients, leading to specific relationships among the coefficients, such as α1=β1=0 and β2=α2+α3. The discussion seeks clarification on the derivation of these relationships and the implications of ignoring coefficients beyond i=4. Participants also request references for Margules' original work and explanations of the terms used in the formulas. Understanding these concepts is crucial for accurately applying the Margules power series in thermodynamic calculations.
jinayb
Margules suggested a power series formula for expressing the activity composition variation of a binary system.
lnγ1=α1x2+(1/2)α2x2^2+(1/3)α3x2^3+...
lnγ2=β1x1+(1/2)β2x1^2+(1/3)β3x1^3+...
Applying the Gibbs-Duhem equation with ignoring coefficients αi's and βi's higher than i=3, we can obtain α1=β1=0, β2=α2+α3, β3=-α3
I don't know how that relationship between coefficients is derived.
Also, what would be the relationship when higher than i=4 is ignored?
Please help!
Mathematics news on Phys.org
Could you elaborate a bit? E.g.
a) "Margules suggested ..." where? Reference?
b) Here is explained how you can type formulas on PF: https://www.physicsforums.com/help/latexhelp/
c) "the activity composition variation of a binary system" means what? Forces? Number system?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
