Mass collides with spring and mass
  • Thread starter Thread starter NRasmus1
    Mass Spring
The discussion revolves around a collision involving two blocks and a spring, where block m1 (1.60 kg) moves right at +4.00 m/s and block m2 (2.10 kg) moves left at -2.50 m/s. The spring constant is given as 600 N/m, and the goal is to find the velocity of block m2 when block m1 is moving at +3.00 m/s, as well as the distance the spring is compressed at that moment. Participants suggest using conservation of momentum and conservation of energy to formulate two equations for the two unknowns. A step-by-step approach to setting up these equations is requested for clarity. The discussion emphasizes the complexity of the system and the need for a structured method to solve it.
NRasmus1
A block of mass m1=1.60kg initially moving to the right with a speed of +4.00m/s on a frictionless horizontal track collides with a spring attached to a second block of mass m2=2.10kg initially moving to the left with a speed of -2.50m/s. The spring constant is 600N/m. At the instant block 1 is moving to the right with a speed of +3.00m/s, determine the velocity of block 2. Determine the distance the spring is compressed at that instant.
KE=1/2mv^2
Elastic PE=1/2Kx^2
Fp=Kx
Fs=-Kx
I'm going to start with conservation of energy, but this is too complex of a system for me to even begin. A step by step of how to set up this equation would be most helpful. Thank you all for your help!
Try conservation of momentum.
Use both conservation of energy and comservation of momentum to get 2 equations for the 2 unknowns.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
