A Mass dropped onto rotating disk
A mass dropped onto a rotating disk with a radial vane will be influenced by both radial and tangential forces as it slides along the vane. The mass will travel off the disk at an angle due to these force components, but the exact direction depends on the dynamics of the system. If the vane is curved, it can potentially minimize the radial velocity component while maximizing the tangential component, suggesting an optimal shape for the vane could exist. The discussion emphasizes the importance of frictionless conditions, which dictate that forces act perpendicular to the surfaces involved. Overall, the interaction of the mass with the vane and disk is complex and requires careful consideration of physical principles to accurately predict the mass's trajectory.
Jazzjohn
TL;DR Summary
How would a mass fly off a rotating disk/vane system?
Picture a flat disk of radius r with a radial vane. The disk is rotating at angular velocity w. Assume the vane is straight, starts at the center and ends at the perimeter of the disk.
A very small round mass ( of m grams) is dropped onto the disk very near the center. The vane contacts it and pushes it. The mass slides along the vane and travels toward the disk rim.
Assume no friction along the vane and disk surfaces.
At the end of the vane (at the edge of the disk), the mass is spun off the disk.
1. What direction does it travel off the disk? Intuition tells me there will be a radial force component in addition to the tangential force component.
2. If the vane is not restricted to a straight line, what shape will increase the tangential direction while reducing the radial direction? Is there a theoretical optimal shape for a given mass size?
There are both radial and tangential velocity components relative to the fixed surface below the disk.
If the groove curves towards the edge, then the mass may come out with minimal radial velocity component.
Jazzjohn said:
Summary: How would a mass fly off a rotating disk/vane system?
Your intuition needs to be tempered by logic. All contacts are assumed frictionless. A frictionless surface can only a force perpendicular and away from it. The vane extends along a radius and can only exert a force tangent perpendicular to the radius. The disk is horizontal and can only exert a force "up", perpendicular to the radius.
Conservation of energy arguments work, even when made using the rotating frame. There is a centrifugal potential associated with a uniformly rotating frame.
I would do this problem using the Lagrange multiplier approach. The KE in polar coordinates is: ##T = \frac{1}{2}m \dot r^2+\frac{1}{2}m r^2 \dot \theta^2##, and this problem has no potential so ##V=0##. Then the rotating vane can be represented by the constraint ##\theta=\omega t##. This gives us the constrained Lagrangian $$L=\frac{1}{2}m \dot r^2+\frac{1}{2}m r^2 \dot \theta^2+\lambda(\theta-\omega t)$$
The Euler Lagrange equations then give us $$ m(r \dot \theta^2-\ddot r)=0$$ $$\lambda-mr(2\dot r \dot \theta+r \ddot \theta)=0$$ $$ -t \omega + \theta=0$$ which, assuming ##r(0)=r_0## and ##\dot r(0)=0## we can solve to obtain $$r(t)=r_0 \cosh(\omega t)$$
You could do this by changing the constraint equation, but I will leave that as an exercise for the interested reader
@Jazzjohn You ought to make some attempt next time when posting a problem.
To improve reaction acceleration times & direction backwards in the axial direction rather than radial and tangential, one needs to capture the particle mass in a curved spiral that rotates the axis and captures the mass by spinning fast enough to have the rotational duration between vanes less than the mass linear velocity so as not to miss it.
But we think that the spiral will allow the mass to slide, scoop and redirect , we would be making an invalid assumption on the stiffness and elastic properties of both materials combined. Until all assumptions are stated, the question is actually invalid. (remember this in future as it can lead to false positive conclusions)
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
