B Mass estimate only through mass rate of change
  • B
  • Thread starter Thread starter FranzS
The discussion centers on the challenge of estimating the mass of objects with non-homogeneous density based solely on how mass changes with dimensions. The original poster expresses uncertainty about solving the problem, likening it to an indefinite integral with an unknown constant. A key point raised is that without knowing the initial mass, distinguishing between different material compositions when adding mass becomes impossible. Responses suggest that the intuition of using later estimates to correct earlier ones is flawed, as it does not provide a reliable method to determine the initial mass. Ultimately, the consensus is that without specific initial mass data, accurate estimations cannot be achieved.
FranzS
TL;DR Summary
How to estimate the mass of partially non-homogeneous bodies.
Hello,
do you ever get the feeling that you cannot grasp an apparently easy concept? Like setting up the problem, writing down some equations and not knowing how to go on?
Well, I'm in that situation right now.
So, I would like to estimate the mass of certain objects by knowing only and precisely how the mass changes when the object dimensions change. The problem is the objects do not have a homogeneous density.
This smells like solving an indefinite integral and getting stuck with an unknown ##+C##, so to speak.
Therefore, a part of my intuition tells me I have no chance of finding a solution (not even an approximate one).
However, I'll explain what another part of my intuition tells me with the following simplified example.
Let's suppose I have a cylinder (meant as the basic geometrical shape) with base radius ##R## and height ##x_0##. The cylinder is made of steel but has some holes ("air bubbles") inside, hence I cannot calculate its exact mass ##m_0## using its outside volume (and the steel density ##\rho_s##). I can only give a rough estimate of it, and I'll call it ##\tilde{m}_0##.
Then, I can somehow extend this cylinder to a height ##x>x_0##, thus making it longer/taller by an amount ##\Delta x = x - x_0##, and I'll do that by adding pure steel to the original cylinder.
Therefore, I'm adding an exact mass ## \Delta m (x) = \rho_s \cdot \left( \pi R^2 \Delta x \right) ## and my estimate for the overall mass of the extended cylinder will be ##\tilde{m} (x) \approx \tilde{m}_0 + \Delta m (x) ##, whereas the actual mass is ##m(x) = m_0 + \Delta m (x)##.
Now, as I extend the cylinder more and more, always by adding pure steel, the overall mass will be approximately equal to the added mass only. In other words:
\lim_{x\to\infty} \frac{\tilde{m}(x)}{m(x)} = 1
On the ##x, y## plane (with ##y## being the mass), ##\tilde{m}(x)## and ##m(x)## would be two parallel lines that always differ by the quantity ## \lvert \tilde{m}_0 - m_0 \rvert ## and it's only the relative/percentage error between ##\tilde{m}(x)## and ##m(x)## that decreases as ##x## increases.
However, as said above, part of my intuition tells me that I should be able to use the more accurate values of ##\tilde{m}(x \gg x_0)##, which are acceptable estimates, in order to correct the less accurate values ##\tilde{m}(x \sim x_0)##, in a sort of feedback / retrofit style.
Is my intuition wrong?
Thanks to everyone who'll be willing to chime in.
Mathematics news on Phys.org
This smells like solving an indefinite integral and getting stuck with an unknown +C, so to speak.
In essence, the problem you're trying to solve is a differential equation of the form ##\frac {dm}{dt} = \text{some function of t}##. (I'm assuming that the rate of change of mass is with respect to time t.) The solution will be a family of functions that differ from each other by a constant. To nail down the precise function you need to know the mass at some specific time.
FranzS said:
... However, as said above, part of my intuition tells me that I should be able to use the more accurate values of ##\tilde{m}(x \gg x_0)##, which are acceptable estimates, in order to correct the less accurate values ##\tilde{m}(x \sim x_0)##, in a sort of feedback / retrofit style.
I believe it is wrong. Consider two example cases for the initial cylinder of length ##x_0##:
1) the cylinder is made pure steel;
2) the cylinder is made of steel with air bubbles.
In both cases, adding known amounts of extra pure steel will increase the total length in exactly the same way.
So, knowing only the added mass of steel and the new length, there is no way to distinguish between 1) and 2). You can never find ##m_0## this way.
Thanks for offering this point of view. In this case, not knowing ##m(t_0) = m_0##, it makes no sense to use ##m(t \gg t_0) \approx \Delta m(t \gg t_0)## as an estimate for the value at a certain point, because I would conclude that ##m_0 =0## and that's useless.
Thanks for your reply. The more I think about it, the more I'm convinced that my intuition was completely wrong.
Likes Steve4Physics
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
