Mass on a Spring Homework: Max Speed, Energy, Acceleration
  • Thread starter Thread starter ddsMom
    Mass Spring
The discussion focuses on a mass-spring system in simple harmonic motion, with a mass of 0.4 kg and a spring constant of 100 N/m. The maximum speed of the mass is calculated to be approximately 4.74 m/s, confirming the formula used for maximum speed. The energy stored in the system when the speed is half the maximum value is determined to be 1.12 J, based on the relationship between potential and kinetic energy. The acceleration at this speed can be calculated using the formula a_max = A(ω)^2, but requires further clarification on how to apply it at that specific point in the motion. Overall, the conversation emphasizes the conservation of energy in the system and the need for precise calculations to understand the dynamics involved.
ddsMom
A mass of .4 kg is connected to a spring with a spring constant of 100 N/m, slides on a frictionless horizontal surface in simple harmonic motion, Its maximum displacement is .3m?
What is the maximum speed of the mass?
What is the energy stored in gthe mass/spring system when its speed is half the maximum value?
What is acceleration of t he mass when its speed is half the maximum value?
m=.4kg
k=100N/m
A(max displacement)=.3m
Vmax=ωA=√k/m(A)=√100/.4 (.3)=4.74m/s CORRECT?
PE=KE
1/2k(A)2 = 1/2m(v)2 so...
1/2(100)(.3)2 = 1/2(.4)(4.74)
4.50 = 4.50
so...1/2(.4)(4.74/2)2 = 1.12J IS THIS CORRECT?
amax=A(ω)2, but where would I use the speed half max value?
I would really like to learn this. It's been 20+ years since I have taken a Physics course.
Thank you!
ω = 15.8 rad/s , so ωA = 4.745 m/s ; correct.
the PE = KE statement is true for PE average = KE average
(and for PE max = KE max , which formulas you used)
But at any instant (read "stored WHEN its speed ..."), PE + KE = E total.
... when v = ½ v_max , KE = ¼ KE_max . so how much PE is there?
Likes 1 person
Hi Mom, and welcome to PF. Creative use of the provided template!
(Values for m, k and a are more like "given/known data" than equations)
Just so we're talking about the same problem: The other end of the spring is a fixed point.
"Vmax=ωA=√k/m(A)=√100/.4 (.3)=4.74m/s CORRECT?"
Don't think so. But with a few brackets in the right place and in lower case (all caps is considered shouting in PF and they frown on that...): yes.
We go on with energy stored: no friction means no energy loss. So energy constant. In my humble perception, "energy stored in the mass/spring system" is potential energy from the spring plus kinetic energy from the mass. A constant, also when v=vmax/2.
Value follows from some relevant equation (to be listed under 2...) involving k and xmax.
Story would be different if we were looking at PE only at the point where v=vmax/2. That is not the point where PE=KE for the simple reason that (vmax/2)2= (vmax)2/4 (and not /2).
equation is correct, but this time they don't wan amax but the magnitude of a at some specific point in the cycle. List an expression for displacement as a function of Amax, ω and time (under 2. of course...), differentiate once to get the speed and once again to get the acceleration. Find out where in the cycle you are (follows from one of the givens) and substitution gives you a.
Bedtime for me, but someone else will help you further along.
By the way: 20 years isn't that much (I can tell) and from what I see I don't think you'll take long to catch up. Brava! and good luck!
Likes 1 person
So then would I find E Total first
= 1/2k(A)2 + 1/2 m(v)2
=1/2(100)(.3)2 + 1/2(.4)(4.74)2
E total = 8.99
then subtract value of 1/4m(v)2?
Total energy E is constant given by (1/2)kA2 ,where A is the amplitude.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
