Massive rotating drum on bearings with friction
The discussion revolves around analyzing the forces and friction involved in a rotating drum system with a suspended mass. The user is attempting to determine the coefficient of friction between the drum and its bearings, noting that the forces acting on the drum create a torque that influences its rotation. They express confusion about the role of friction, particularly how it produces torque and affects the normal force on the drum's center of mass. The user clarifies that the drum has a shaft with bearings inserted into it, leading to friction between the drum's inner surface and the bearings. The conversation emphasizes the need to incorporate all forces and torques in the calculations to accurately assess the system's dynamics.
erore
I came across the following example. I have a mass m' that is suspended from a massless rope which is wound around a drum of mass m. The radius of the drum is R. The drum is fixed on a shaft with bearings of radius r. I am supposed to determine coefficient of friction between the bearings and the drum but for now I am stuck with the forces diagram.
I created something like that:
In my solution I add a pair of forces of the same magnitude and opposite direction F^{T''} and F^{T'}. F^{T''} and F^{T} make a force couple which generates some momentum about the axis of the drum (which contributes to rotation motion). However, F^{T'} acts on the center of mass of the drum and adds up with gravitation force. Thus, the resulting force exerted by the drum on the bearing is bigger than if there was no m'. Consequently the friction is bigger too.
My question is whether this is correct. The solution I have only calculates the torque due to m' and does not introduce the force couple therefore it does not have the additional force on the center of mass and consequentially no additional item in the normal force and friction respectively.
I am also curious, the friction itself produces a torque, if my reasoning above is correct, it would create another force couple, giving rise yet to another force acting on the center of mass of the drum which could go on and on. This is confusing for me at the moment.
Friction between what and what? Is the drum attached to something or in contact with something? That will somehow balance the force FT (otherwise the whole setup accelerates downwards).
I am sorry, the first paragraph was nonsense. I corrected. Basically, there is a hole in the middle of the drum of radius r and a shaft with bearings is inserted into that hole. The friction I mention is between the inner hole of the drum and the bearings.
Ah. I think I would draw the friction force at the upper side and in the other direction.
Afterwards, I would add variables for the angular acceleration and the force on the shaft and solve for those.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
