Mastering Integration: Step-by-Step Methods Explained | Homework Help
  • Thread starter Thread starter clurt
    Integration
clurt
Please view the images, i am quite confused(although i know basics). I would very much appreciate an explanation as to how to solve these problems. The step by step approach.
Again, i would appreciate any response explaining how to do this.
For part A, the options are...
1. Power rule
2. logarithym rule
3. Exponential rule
4. Trig rule
5. Inverse trig rule
1. Power rule
2. logarithym rule
3. Exponential rule
4. Trig rule
Seems to me Exponential Expansion'd be better.. But what kind of question is this, anyways?
1. Power rule
2. logarithym rule
3. Exponential rule
4. Trig rule
What have you tried?
Where are you stuck?
You must show an attempt before we can help you. -- See the rules.
im stuck everywhere and i have tried, can't produce anything
1. Power rule
2. logarithym rule
3. Exponential rule
4. Trig rule
I don't think the questions are in parts, as such. I think you're supposed to choose the best option between those "parts" - i.e. if you think you can the integral directly, then choose the first option. If you think you should sub, choose the second, etc.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
