Mastering Motion on a Plane: Solving the Defiance Drake Question
  • Thread starter Thread starter CJoy
The discussion revolves around a physics problem involving Defiance Drake, who must navigate a 90-degree turn while fleeing a parasite using her jet boots and a handhold. Key considerations include the forces exerted by her arms and the potential for dislocation or loss of grip rather than buckling. The relevant equations of motion and force are provided, emphasizing the need to apply them to determine if she can successfully make the turn. Participants suggest focusing on the tension in her arms and the dynamics of circular motion. The conversation highlights the importance of correctly interpreting the physical scenario to solve the problem effectively.
CJoy
Defiance Drake is fleeing a Cubarb parasite (evil creatures which are floating multicolored cubes and eat humans) in a seemingly derelict cargo freighter. In addition to the recoil she gained from flinging her air cannister at the parasite, she once more uses her jet boots to give herself a velocity of 5 m/s (as a reminder her mass is 70 kg). Ahead of her, the corridor takes a 90 degree turn to the right. Defiance grabs a handhold on the wall intending to swing around the corner (describing part of a circle). If her arms can provide up to 3000 N of force before buckling, and are 0.85m long, can she make the turn? If she makes the turn (at constant speed), how would her velocity change?
F=ma
a=v^2/r
F=mv^2/r
a(x)=(-pCA/2m)*v(x)*sqrt(v(x)^2+v(y)^2)
a(y)=-g-(-pCA/2m)*v(y)*sqrt(v(x)^2+v(y)^2)
This is the start of a new topic (Dynamics 2: Motion on a Plane) and I don't know how to start the problem
CJoy said:
Homework Statement: Defiance Drake is fleeing a Cubarb parasite (evil creatures which are floating multicolored cubes and eat humans) in a seemingly derelict cargo freighter. In addition to the recoil she gained from flinging her air cannister at the parasite, she once more uses her jet boots to give herself a velocity of 5 m/s (as a reminder her mass is 70 kg). Ahead of her, the corridor takes a 90 degree turn to the right. Defiance grabs a handhold on the wall intending to swing around the corner (describing part of a circle). If her arms can provide up to 3000 N of force before buckling, and are 0.85m long, can she make the turn? If she makes the turn (at constant speed), how would her velocity change?
Homework Equations: F=ma
a=v^2/r
F=mv^2/r
You may be confused by the reference to her arms buckling. I am.
I would assume the handhold is on the right-hand wall, and the problem is not whether her arms would buckle but whether (either) her arms would dislocate or her hands lose their grip. I.e. the arms are under tension, not compression.
You have quoted a suitable equation. Apply it.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
