Math Challenge - December 2021
  • #71
The missing rest of the month is added now.
  • #72
TeethWhitener said:
Edit: ignore what I wrote. I didn’t consider that the number could be prime all by itself. The first two conditions (##2\mod3## and ##3\mod4##) tell us that the solution will be an integer of the form ##12n-1##. The first and third (##2\mod5##) conditions tell us that it ends in a 7. The smallest number that satisfies this is 47.
Pretty sure a little piece of code could do this much quicker, but here’s my calculator-free solution:
The smallest prime factor will be at least 7. Looking at the modular behavior of multiples of 7, we find that a family of solutions consisting of 7 multiplied by a number satisfying the following expressions simultaneously:
$$3n+2$$
$$4n+1$$
$$5n+1$$
The smallest number of this form is 41 (this is easy to find by noting that ##4n+1## and ##5n+1## together imply ##20n+1##), which gives a solution of ##7\times41=287##.
To check whether this is the smallest integer satisfying the equations, we note that ##287<\sqrt{17}##, so the smallest prime factor of the solution will either be 7, 11, or 13. The requirements for the multipliers of 11 are:
$$3n+1$$
$$4n+1$$
$$5n+2$$
The smallest number satisfying these expressions is 37 (again, easy to find noting that ##3n+1## and ##4n+1## together imply ##12n+1##), which gives the solution ##11\times37=407>287##.
The requirements for multipliers of 13 are:
$$3n+2$$
$$4n+3$$
$$5n+4$$
The smallest number satisfying these expressions is 59 (the conditions are equivalent to ##3n-1##, ##4n-1##, and ##5n-1## together, or ##60n-1##), giving ##13\times59=767>287##, so our answer is in fact 287.
The answer is correct, the reasoning is not: ##32\equiv 2 \,(3)\wedge 32\equiv 2\,(5)## and ##32## does not end on a ##7.##
Another idea how to prove it?
  • #73
fishturtle1 said:
We consider the first map first. Suppose ##f(a) = f(b)##. Then ##\lbrace a \rbrace =\lbrace b \rbrace##. This implies ##a = b##. So, ##f## is injective. If ##\vert X \vert = 1##, then ##f## is surjective. Suppose ##\vert X \vert \ge 2##. Then we can write ##X = \lbrace a, b, \dots \rbrace##. Then ##\lbrace a, b \rbrace \in \mathcal{P}(X)## and ##f(x) \neq \lbrace a, b \rbrace## because ##\vert f(x) \vert = 1## for all ##x \in X##. So, ##f## is surjective iff ##\vert X \vert = 1##. Lastly, we see ##f^{-1}(\emptyset) = \lbrace x \in X : f(x) = \emptyset \rbrace = \emptyset## because ##\vert f(x) \vert = 1## for all ##x \in X##.
Next, we consider the second map. Let ##X =\lbrace a ,\dots \rbrace## and define ##A = \lbrace a \rbrace## and ##B = \emptyset##. Then $$g((A,B)) = A \cup B = \lbrace a \rbrace \cup \emptyset = \lbrace a \rbrace = \emptyset \cup \lbrace a \rbrace = B \cup A = g((B,A))$$
and ##(A,B) \neq (B,A)##. This shows ##g## is not injective. Let ##C \in \mathcal{P}(X)##. Then ##g((C,\emptyset)) = C \cup \emptyset = C##. This shows ##g## is surjective. Lastly, observe for arbitrary ##A, B \in \mathcal{P}(X)##, if ##A \cup B = \emptyset##, then ##A \subseteq \emptyset## and ##B \subseteq \emptyset##. This implies ##A = \emptyset## and ##B = \emptyset##. So, ##g^{-1}(\emptyset) = \lbrace (\emptyset, \emptyset) \rbrace##. []
Almost correct! In case ##|X|=1## we have ##\mathcal{P}(X)=\{\emptyset\, , \,\{x\}\}## but ##\emptyset \not\in f(X)## hence ##f## isn't surjective in that case either: ##\emptyset \notin X.##
Likes fishturtle1
  • #74
The condition ##2\mod5## means the number ends in a 2 or a 7, and ##3\mod4## means the number has to be odd.
  • #75
and not second and third!
  • #76
mathwonk said:
for #9, I believe that a loop is null homologous iff every holomorphic one - form integrates to zero over it. does that do it? (just throwing out an approach for complex analysts, since a topologist presumably knows that homology is a continuous invariant; or does 0 - homologue have some other meaning?)
Cauchy is correct, but it can be used in either of the two directions, hence it is necessary to at least sketch which proof is meant (a proof where the chain rule is seen would be preferred), rather than saying Cauchy.
  • #77
Oh, oops…
  • #78
TeethWhitener said:
Oh, oops…
Here is the proof by the Chinese remainder theorem:There is a solution ##x## since ##3,4,5## are pairwise coprime by the Chinese remainder theorem, and all solutions are congruent modulo ##M=3\cdot4\cdot5=60.## The calculation is
\begin{align*}
7\cdot 3 +(-1)\cdot \dfrac{M}{3}=1 &\Longrightarrow \alpha_1=-20\\
4\cdot 4 +(-1)\cdot \dfrac{M}{4}=1 &\Longrightarrow \alpha_2=-15\\
5\cdot 5 +(-2)\cdot \dfrac{M}{5}=1 &\Longrightarrow \alpha_3=-24
\end{align*}
which results in
x=2\cdot \alpha_1+3\cdot\alpha_2+2\cdot\alpha_3=-133 \equiv 47 \mod M.
  • #79
For 30 I observe that ##\nabla \cdot F = 2z##, so by theorem of Gauss ##\int_A \langle F, n \rangle dS = \int 2z dV - \cancel{123\int_{\mathrm{cover}} dS} + \cancel{123\int_{\mathrm{base}} dS} = \pi R^2 h^2##.
(Directly, one could parameterise ##A## by ##\Phi(\theta, z) = (R\cos{\theta}, R\sin{\theta}, z)## to obtain a surface element ##n dS = R(\cos{\theta}, \sin{\theta}, 0)d\theta dz## and then an integral ##\int_A \langle F, n \rangle dS = R^2 \int z dz \int d\theta = \pi R^2 h^2##).
Likes fresh_42
  • #80
ergospherical said:
For 30 I observe that ##\nabla \cdot F = 2z##, so by theorem of Gauss ##\int_A \langle F, n \rangle dS = \int 2z dV +\cancel{123\int_{\mathrm{cover}} dS} - \cancel{123\int_{\mathrm{base}} dS} = \pi R^2 h^2##.
I guess it will do no harm to elaborate on these two solutions for those who do not "see" it at once.
One possible parameterization is
\begin{align*}
\phi\, : \,[0,2\pi) \times [0,h]&\longrightarrow A\\
(\varphi,z)&\longmapsto (R\cos\varphi ,R\sin\varphi ,z)
\end{align*}
The height of the cylinder is given by ##z,## and for a fixed ##z## we have a circle parallel to the plane ##z=0## described by polar coordinates. ##\phi## is a bijection because every point on ##A## has exactly one pair of parameters ##(\phi,z).##
We use this parameterization ##\phi## to calculate the surface integral.
\begin{align*}
\int_A \langle F,n \rangle\,d^2r&=\int_{0}^{2\pi}\int_{0}^{h}\langle F\circ\phi,n \rangle\,\|\partial_\varphi \phi \times \partial_z \phi\| \,dz\,d\varphi \\
&=\int_{0}^{2\pi}\int_{0}^{h}\langle F\circ\phi,\partial_\varphi \phi \times \partial_z \phi \rangle\, \,dz\,d\varphi \\
&=\int_{0}^{2\pi}\int_{0}^{h}\langle \begin{pmatrix}
zR\cos\varphi \\zR\sin\varphi \\123 \end{pmatrix},\begin{pmatrix}
R\cos\varphi \\R\sin\varphi \\0 \end{pmatrix} \rangle\, \,dz\,d\varphi \\
&=\int_{0}^{2\pi}\int_{0}^{h} zR^2\left(\cos^2\varphi +\sin^2\varphi \right)\,dz\,d\varphi \\
&=\int_{0}^{2\pi}\int_{0}^{h} zR^2\,dz\,d\varphi = 2\pi R^2\left[\dfrac{z^2}{2}\right]_{z=0}^{z=h}=h^2\pi R^2
\end{align*}
We could alternatively use Gauß's divergence theorem. This uses closed surfaces, so we have to consider base and cover. Let ##C## be the volume of the cylinder, ##D_1## its base, and ##D_2## its cover. Then ##\partial Z=A\cup D_1\cup D_2.## Note that the two integrals over ##D_1## and ##D_2## cancel each other since the normal vectors ##n## are parallel to the ##z##-axis, but pointing into opposite directions, and the third component of ##F## is constant.
\begin{align*}
\int_{D_1} \langle F,n \rangle\,d^2r + \int_{D_2} \langle F,n \rangle \, d^2r &= \int_{D_1}\langle F,\begin{pmatrix}
0\\0\\1 \end{pmatrix} \rangle \,d^2r+ \int_{D_2}\langle F,\begin{pmatrix}
0\\0\\-1 \end{pmatrix} \rangle\,d^2r\\&=
\int_{D_1}123\,d^2r + \int_{D_2}-123\,d^2r \\&=123(\pi R^2-\pi R^2)=0
\end{align*}
Therefore
\int_{\partial Z}\langle F,n \rangle\,d^2r = \int_{A}\langle F,n \rangle\,d^2r+\int_{D_1}\langle F,n \rangle\,d^2r+\int_{D_2}\langle F,n \rangle\,d^2r=\int_{A}\langle F,n \rangle\,d^2r
Now we apply Gauß's divergence theorem
\begin{align*}
\int_{\partial Z}\langle F,n \rangle\,d^2r&=\int_Z\operatorname{div} F\,d^3r\\&=
\int_{0}^{R}\int_{0}^{2\pi}\int_{0}^{h}(\operatorname{div}F)\circ \phi \cdot |\det J_\phi|\,dz\,d\varphi \,d\rho\\
&=\int_{0}^{R}\int_{0}^{2\pi}\int_{0}^{h} 2z\rho \,dz\,d\varphi \,d\rho\\
&=2\cdot \dfrac{R^2}{2}\cdot\dfrac{h^2}{2}\cdot 2\pi = h^2\pi R^2
\end{align*}
Likes ergospherical
  • #81
Definition: Three or more points that lie on the same line are called collinear.
Proof: We write ##\mathcal{P} = \lbrace p_1, \dots, p_n \rbrace##. We prove the statement by inducting on ##n##.
base case: ##n = 2##. Consider the line that passes through the points ##p_1## and ##p_2##. There are no other points, so this line contains exactly two elements of ##\mathcal{P}##.
inductive step: Proceeding by induction, we suppose that the statement is true for ##n-1 \ge 2##. We will show the statement holds for ##n## points. By assumption, ##p_1, \dots, p_{n-1}## are not all collinear. By the inductive hypothesis, we can find a line, say ##l## that contains exactly two of these points. WLOG, suppose these two points are ##p_1## and ##p_2##. If ##p_n## is not contained in ##l##, then we are done. If ##p_n## is on ##l##, then ##p_1, p_2, ## and ##p_n## are collinear which contradicts our assumption that ##p_1, \dots, p_n## are not all collinear. []
fresh_42 said:
Let P be a finite set of points in a plane, that are not all collinear.
does this mean no three points in ##\mathcal{P}## are collinear? Or only a specific ##p_1, p_2, p_3##?
  • #82
@fishturtle1 This is fairly famous result, so I feel confident in assuming that @fresh_42 meant that not all of the points lie on the same line. With your interpretation, there would be absolutely nothing to prove (if no three points are collinear, then any line passing through any two of the points would work).
Likes fishturtle1
  • #83
fresh_42 said:
28. Consider the circle segment above ##A = (-1, 0)## and ##B = (1, 0)## of $$
x^2 + \left(y + \dfrac{1} {\sqrt{3}}\right)^2 = \dfrac {4}{3}
The point ##P := \left(\dfrac{1} {\sqrt{3}}, 1 - \dfrac{1} {\sqrt{3}} \right)## lies on this segment. Calculate the height ##h## of the circle segment, and ##|AP| + |PB|##.
Since the given circle's equation can be rewritten as ##\left(x-0\right)^2 + \left(y - \dfrac{-1} {\sqrt{3}}\right)^2 = \left(\dfrac {2}{\sqrt{3}}\right)^2##, it must be centered at the point ##Q = \left(0, \dfrac {-1}{\sqrt{3}}\right)## and have the radius ##\dfrac {2}{\sqrt{3}}##. Points ##A## and ##B## lie on this circle and therefore the line segment is a chord of this circle. Since the line segment ##\overline{AB}## chord lies on the x-axis ##(y = 0)##, the height of the circle segment above ##\overline{AB}## must equal the radius plus the y-coordinate of the center point ##Q##, i.e. ##h = \dfrac {2}{\sqrt{3}} + \left(\dfrac{-1} {\sqrt{3}}\right) = \dfrac{1} {\sqrt{3}}##.
|AP| = \sqrt{\left(\dfrac{1} {\sqrt{3}} - (-1)\right)^2 + \left(\left(1 - \dfrac{1} {\sqrt{3}}\right) - 0\right)^2} = 2 \sqrt{\dfrac{2}{3}}
|PB| = \sqrt{\left(1 - \dfrac{1} {\sqrt{3}}\right)^2 + \left(0 - \left(1 - \dfrac{1} {\sqrt{3}}\right) \right)^2} = \sqrt{2 \left(1 - \dfrac{1} {\sqrt{3}}\right)^2} = \sqrt{2} - \sqrt{\dfrac{2}{3}}
\Rightarrow |AP| + |PB| = \sqrt{2} + \sqrt{\dfrac{2}{3}}
Likes fresh_42
  • #84
Hi @fresh_42. I notice you have given the solutions for December's math challenges. For problem 2 you've written
\begin{align*}
I = \frac{1}{2} \log^2 \frac{a}{a+1} = \log^2 \sqrt{\frac{a}{a+1}}
\end{align*}
The final expression (the RHS) seems wrong because isn't ##\log^2 \sqrt{\frac{a}{a+1}} = \dfrac{1}{4} \log^2 \frac{a}{a+1}##?
  • #85
Hi, @Fred Wright. I think you got the right answer for problem 2, but you didn't write it down it terms of ##a##. If you had it would have been:
\begin{align*}
I = \frac{1}{2} \log^2 \frac{z_0}{z_1} \equiv \frac{1}{2} \log^2 \frac{a}{a+1}
\end{align*}
You skipped writing your answer in terms of ##a## and wrote the answer in terms of ##|a|## and ##\phi## instead. This answer was correct except for a slight typo. The exponent in your expression for ##z## should have been:
\begin{align*}
i \tan^{-1} \left( \frac{\sin \phi}{|a| + \cos \phi} \right)
\end{align*}
Another slight typo you made was writing ##I_2 = - Li_2 \left( - \frac{1}{z_0} \right)##. It think ##I_2## should be ##+ Li_2 \left( - \frac{1}{z_0} \right)## instead,
\begin{align*}
I_2 & = \int_0^1 \frac{\log x}{z_0 + x} dx
\nonumber \\
& = boundary \; terms \; - \int_0^1 \frac{\log (z_0 + x)}{x} dx
\nonumber \\
& =boundary \; terms \; - \int_0^1 \frac{\log (1 + \frac{x}{z_0})}{x} dx
\nonumber \\
& = - \int_0^1 \frac{\log (1 + \frac{x}{z_0})}{x} dx
\nonumber \\
& = - \int_0^{- \frac{1}{z_0}} \frac{\log (1 - u)}{u} du
\nonumber \\
& = + Li_2 \left( - \frac{1}{z_0} \right)
\end{align*}
Then
\begin{align*}
I & = I_1 - I_2
\nonumber \\
& = - \left( Li_2 \left( \frac{1}{z_1} \right) + Li_2 \left( - \frac{1}{z_0} \right) \right) .
\end{align*}
  • #86
\begin{align*}
\end{align*}
Thank you! My bad. I have corrected this. I'm afraid it won't be the last sloppy formula.
  • #87
I was just thinking to myself, it is not like @fresh_42 to be sloppery.
  • #88
Thanks for the flowers. I wrote many of these late at night, and who wants to proofread 500+ pages?
  • #89
We are all very grateful! We can learn a lot by reading your solutions!
  • #90
fresh_42 said:
31. Let ##\mathcal{P}## be a finite set of points in a plane, that are not all collinear. Then there is a straight, that contains exactly two points.
When ##\mathcal{P}## contains 3 or more points, and not all are collinear, there will exist a polygonal convex hull all of whose vertices belong to and all other points of ##mathcal{P}## are contained within or lie on the edges of this polygon. Let ##\{P_1, P_2, ..., P_m\} \subset \mathcal{P}## be the ordered vertices of this convex hull polygon (##P_1## can be chosen arbitrarily from the ##m## vertices and the rest of the vertices are named accordingly in order). Let ##A \in \mathcal{P} \setminus \{P_1, P_2, ..., P_{m-1}\}## be the point belonging to ##\mathcal{P}## that is closest to ##P_1## on the line segment ##\overline {P_m P_1}##. In the trivial case, ##A = P_m## and in this case the line containing the line segment ##\overline {P_m P_1}## passes through just 2 points of ##\mathcal{P}##. Even if ##A \neq P_m##, we can find 2 points belonging to ##\mathcal{P}## and lying on or within ##\triangle {A P_1 P_2}## such that the line passing through those 2 points does not contain any other point of ##\mathcal{P}##. This is demonstrated by the following figures.
Figure 1:
Case 1: Line segment ##\overline {P_1 P_2}## lies in a line that passes through only 2 points from ##\mathcal{P}##
Figure 2: Case 2: Line segment ##\overline {P_1 P_2}## contains one or more points from ##\mathcal{P}## other than ##P_1, P_2##. ##\triangle {A P_1 S_1}## does not contain any interior point belonging to ##\mathcal{P}## nor does ##\overline {A S_1}## contain points from ##\mathcal{P}## other than ##A, S_1##. ##\overline {A S_1}## forms an edge of the polygonal convex hull containing all points of ##\mathcal{P}## except ##P_1##. The line passing through this line segment contains no point of ##\mathcal{P}## except ##A, S_1##
Figure 3: Case 3: Line segment ##\overline {P_1 P_2}## contains one or more points from ##\mathcal{P}## other than ##P_1, P_2##, ##\triangle {A P_1 S_1}## contains one or more interior points belonging to ##\mathcal{P}##. Line segment ##\overline {T_k S_1}## forms an edge of the polygonal convex hull containing all points of ##\mathcal{P}## except ##P_1##. The line passing through this line segment does not contain any point from ##\mathcal{P}## except ##T_k## and ##S_1##
Figure 4: Case 4: Line segment ##\overline {P_1 P_2}## contains one or more points from ##\mathcal{P}## other than ##P_1, P_2##. ##\triangle {A P_1 S_1}## does not contain in its interior any point belonging to ##\mathcal{P}##, but ##\overline {P_1 P_2}## has some points from ##\mathcal{P}## other than ##A, S_1##. ##\mathcal{T} \equiv \{T_1, T_2, ..., T_k\} \subset \mathcal{P}## lie within ##\triangle {A P_1 P_2}## and are vertices of the polygonal convex hull containing all points of ##\mathcal{P} \setminus \{P_1, S_1, S_2, ..., S_l\}##. ##j \in \{2, ..., l\}## is the smallest integer such that ##\mathcal{T} \cup \{S_j, P_2, P_3, ..., P_m, A\}## form vertices of a polygonal convex hull (this will contain all points of ##\mathcal{P} \setminus \{P_1, S_1, S_2, ..., S_{j-1}\}##). This implies that ##S_j## does not lie on the line passing through ##\overline {T_{k-1} T_k}##, since otherwise ##T_k## will not be a vertex of the convex hull. And since ##\overline {T_k S_j}## is an edge of the convex hull, the line passing through it cannot contain any point of ##\mathcal{P}## other than ##T_k, S_j##.
Figure 5: Case 5: A special case within case 4 wherein no ##S_j \in \{S_1, ..., S_l\}## meets the condition that both ##T_k## and ##S_j## form vertices of the convex hull of ##\mathcal{P} \setminus \{P_1, S_1, S_2, ..., S_{j-1}\}##. In this case, ##\overline {T_k P_2}## will form an edge of the polygonal convex hull of ##\mathcal{P} \setminus \{P_1, S_1, S_2, ..., S_j\}##, and the line passing through ##\overline {T_k P_2}## will not pass through any point of ##\mathcal{P}## other than ##T_k, P_2##.
  • #91
Sorry, please ignore my previous post (post #90). I think I found a mistake in that solution for question #31. I will attempt to find a correct solution later and make a new post.
  • #92
You do not need an algorithm or any iteration. Consider pairs ##(g,P)## of a straight line in the plane and a point ##P\not\in g.## Then choose a pair such that ##\operatorname{dist}(g,P)## is minimal.
  • #93
I didn't expect a reply to my withdrawn incorrect solution. 💯*💯*💯 thanks for that hint. Below is a solution, hopefully correct this time.
Let ##\mathcal{L} = \{l_1, l_2, ..., l_m\}## be the set of all lines that pass through 2 or more points belonging to ##\mathcal{P} = \{P_1, P_2, ..., P_n\}##. Suppose ##A \in \mathcal{P}, l_i \in \mathcal{L}## be a point and a line such that ##\mathtt{dist}(A, l_i) = \min \limits_{P_j \in \mathcal{P}} \min \limits_{l_k \in \mathcal{P}, P_{j} \notin_{l_k}} \mathtt{dist}(P_j, l_k)##. Such a pair will always exist if not all points of ##\mathcal{P}## are collinear. Without loss of generality, we will assume ##l_i = l_1## for convenience hereafter. By definition, ##l_1## will contain at least two points from ##\mathcal{P}##. We will prove that ##l_1## cannot contain more than 2 points from ##\mathcal{P}##, thus making it a line passing through exactly 2 points from ##\mathcal{P}##.
Let ##B, C## be the two closest points to ##A## among all points from ##\mathcal{P}## lying on ##l_1##. With reference to attached figure, ##h_{A[BC]} \equiv \mathtt{dist}(A, l_1)##, using the notation ##h_{X[YZ]}## to denote the height of vertex ##X## w.r.t. the base ##\bar {YZ}## in triangle ##\Delta {XYZ}##. Note that ##BC## must be the longest edge of ##\Delta ABC## (more precisely, no smaller than the other edges), since otherwise, we could have, for e.g., ##h_{B[AC]} \lt h_{A[BC]}##, i.e. distance between ##B## and line passing through ##A,C## is smaller than ##\mathtt{dist}(A, l_1)##, a contradiction. Therefore, ##\angle{ABC}, \angle{ACB}## must be acute angles as shown in the figure.
Now suppose there exists yet another point ##D \in \mathcal{P}## that lies on ##l_1##. Without loss of generality, we can assume that it lies to the right of point ##C##. Let ##l_2 \in \mathcal{L}## denote the line passing through ##A, D##. From the figure, we see that ##\mathtt{dist}(C, l_2) = h_{C[AD]}##. Using the area computation formulae for triangle ##\Delta {AQ_{1}D}##, it follows that ##h_{A[BC]} \times \mathtt{len}(Q_{1}D) = h_{C[AD]} \times \mathtt{len}(AD)##. Since ##\mathtt{len}(AD) \gt \mathtt{len}(Q_{1}D)## (as ##AD## is the hypotenuse of ##\Delta {AQ_{1}D}##), it follows that ##h_{C[AD]} \lt h_{A[BC]}##, i.e. ##\mathtt{dist}(C, l_2) < \mathtt{dist}(A, l_1)##. But this contradicts the initial assumption that ##\mathtt{dist}(A, l_1)## is the minimum possible distance between any point in ##\mathcal{P}## and any line in ##\mathcal{L}##. Since the contradiction arises only when we assume that there exists a point ##D## as defined above, it must be the case that such as point cannot exist. Hence, ##l_1## must contain only two points from ##\mathcal{P}##.
  • #94
Once again I found a mistake in my solution. This time in one of equalities used in the proof. Posting the correction here.
To show that ##h_C[AD] < h_{A[BC]}## if a point ##D## exists as described in my previous post, I must have used an inequality since I was comparing two different triangles.
The area of ##\Delta AQ_{1}D## is ##\dfrac{1}{2} \times h_{A[BC]} \times \mathtt{len}(Q_1D)##. The area of ##\Delta ACD## is ##\dfrac{1}{2} \times h_{C[AD]} \times \mathtt{len}(AD)##. From the figure, it can be seen that the area of ##\Delta AQ_{1}D## must be larger than that of ##\Delta ACD##. Hence we get:
\dfrac{1}{2} \times h_{A[BC]} \times \mathtt{len}(Q_1D) > \dfrac{1}{2} \times h_{C[AD]} \times \mathtt{len}(AD) \Rightarrow h_{A[BC]} > \dfrac{\mathtt{len}(AD)}{\mathtt{len}(Q_1D)} \times h_{C[AD]}
Since ##\mathtt{len}(AD) > \mathtt{len}(Q_1D)## (as ##AD## is the hypotenuse of ##\Delta AQ_1D##), it follows that ##h_{A[BC]} > h_{C[AD]}##, i.e. ##\mathtt{dist}(A, l_1) > \mathtt{dist}(C, l_2)##, but this contradicts the initial assumption about the minimality of ##\mathtt{dist}(A, l_1)##.
The rest of the solution is the same as in the previous post.
9K
10K
23K
12K
11K
9K
