- 19,217
- 24,767
Questions
1. Consider the ring ##R= C([0,1], \mathbb{R})## of continuous functions ##[0,1]\to \mathbb{R}## with pointwise addition and multiplication of functions. Set ##M_c:=\{f \in R\mid f(c)=0\}##.
(a) (solved by @mathwonk ) Show that the map ##c \mapsto M_c, c \in [0,1]## is a bijection between the interval ##[0,1]## and the maximal ideals of ##R##.
(b) Show that the ideal ##M_c## is not finitely generated.
Hint: Assume not and take a generating set ##\{f_1, \dots, f_n\}##. Consider the function ##f = |f_1| + \dots + |f_n|## and play with the function ##\sqrt{f}## to obtain a contradiction.2. We all know that the geometric mean is less than the arithmetic mean. I memorize it with ##3\cdot 5 < 4\cdot 4##. Now we consider the arithmetic-geometric mean ##M(a,b)## between the two others. Let ##a,b## be two nonnegative real numbers. We set ##a_0=a\, , \,b_0=b## and define the sequences ##(a_k)\, , \,(b_k)## by
a_{k+1} :=\dfrac{a_k+b_k}{2}\, , \,b_{k+1}=\sqrt{a_kb_k}\quad k=0,1,\ldots
Then the arithmetic-geometric mean ##M(a,b)## is the common limit
\lim_{n \to \infty}a_n = M(a,b) = \lim_{n \to \infty}b_n
It is not hard to show that both sequences converge and that their limit is the same by using the known inequality and the monotony of the sequences.
Prove that for positive ##a,b\in \mathbb{R}## holds
T(a,b):=\dfrac{2}{\pi} \int_0^{\pi/2}\dfrac{d\varphi}{\sqrt{a^2\cos^2 \varphi +b^2 \sin^2 \varphi }} = \dfrac{1}{M(a,b)}
$$3. (solved by @StoneTemplePython ) If ##A,B,C,D## are four points in the plane, show that
\operatorname{det} \begin{bmatrix}
0&1&1&1&1 \\ 1&0&|AB|^2&|AC|^2&|AD|^2 \\ 1&|AB|^2&0&|BC|^2&|BD|^2 \\ 1&|AC|^2&|BC|^2&0&|CD|^2 \\ 1&|AD|^2&|BD|^2&|CD|^2&0
\end{bmatrix} = 0
$$4. Let ##T \in \mathcal{B}(\mathcal{H}_1,\mathcal{H}_2)## a linear, continuous (= bounded) operator on Hilbert spaces.
Prove that the following are equivalent:
(a) ##T## is invertible.
(b) There exists a constant ##\alpha > 0##, such that ##T^*T\geq \alpha I_{\mathcal{H}_1}## and ##TT^*\geq \alpha I_{\mathcal{H}_2}\,.## ##A \geq B## means ##\langle (A-B)\xi\, , \,\xi \rangle \geq 0## for all ##\xi\,.##5. Let ##a,b \in \mathbb{F}## be non-zero elements in a field of characteristic not two. Let ##A## be the four dimensional ##\mathbb{F}-##space with basis ##\{\,1,\mathbf{i},\mathbf{j},\mathbf{k}\,\}## and the bilinear and associative multiplication defined by the conditions that ##1## is a unity element and
\mathbf{i}^2=a\, , \,\mathbf{j}^2=b\, , \,\mathbf{ij}=-\mathbf{ji}=\mathbf{k}\,.
Then ##A=\left( \dfrac{a,b}{\mathbb{F}} \right)## is called a (generalized) quaternion algebra over ##\mathbb{F}##.
Show that ##A## is a simple algebra whose center is ##\mathbb{F}##.6. Prove that the quaternion algebra ##\left( \dfrac{a,1}{\mathbb{F}} \right)\cong \mathbb{M}(2,\mathbb{F})## is isomorphic to the matrix algebra of ##2\times 2## matrices for every ##a\in \mathbb{F}-\{\,0\,\}\,.##7. (solved by @Not anonymous ) Show that there are infinitely many primes of the form ##4k+3\, , \,k\in \mathbb{N}_0##.8. (solved by @benorin ) Do ##\displaystyle{\sum_{n=0}^\infty}\, \dfrac{(-1)^n}{\sqrt{n+1}}## and the Cauchy product ##\left( \displaystyle{\sum_{n=0}^\infty}\, \dfrac{(-1)^n}{\sqrt{n+1}} \right)^2## converge or diverge?9. (solved by @DEvens ) Consider the curve ##\gamma\, : \,\mathbb{R}\longmapsto \mathbb{C}\, , \,\gamma(t)=\cos(\pi t)\cdot e^{\pi i t}\,.##
(a) Find the minimal period of ##\gamma##,
(b) prove that ##\gamma(\mathbb{R})\equiv\{\,(x,y)\in \mathbb{R}^2\,|\,x^2+y^2-x=0\,\}##,
(c) show that ##\gamma(\mathbb{R})## is symmetric to the ##x-##axis,
(d) parameterize ##\gamma## with respect to its arc length.10. (solved by @DEvens ) Let ##\gamma\, : \,I \longrightarrow \mathbb{R}^n## be a regular curve with unit tangent vector ##T=\dfrac{d}{dt} \gamma\,.## A (orthonormal) frame is a (smooth) ##C^\infty-## transformation ##F\, : \,I \longrightarrow \operatorname{SO}(n)## with ##F(t)e_1=T(t)## where ##\{\,e_i\,\}## is the standard basis of ##\mathbb{R}^n\,.## The pair ##(\gamma,F)## is called a framed curve, and the matrix ##A## given by ##\dfrac{d}{dt}F=F'=FA## is called derivation matrix of ##F##.
Let ##F_0\, : \,\mathbb{R}\longrightarrow \operatorname{SO}(n)## be a frame of a regular curve ##\gamma\, : \,\mathbb{R}\longrightarrow \mathbb{R}^n##. Show that
(a) If ##F\, : \,\mathbb{R}\longrightarrow \operatorname{SO}(n)## is another frame of ##\gamma##, then there exists a transformation ##\Phi\, : \,\mathbb{R}\longrightarrow \operatorname{SO}(n)## with ##\Phi(t)e_1=e_1## for all ##t\in \mathbb{R}## and ##F=F_0\Phi\,.##
(b) If on the other hand ##\Phi\, : \,\mathbb{R}\longrightarrow \operatorname{SO}(n)## is a smooth transformation with ##\Phi(t)e_1=e_1\,,## then ##F:=F_0\cdot\Phi## defines a new frame of ##\gamma##.
(c) If ##A_0## is the derivation matrix of ##F_0##, and ##A## the derivation matrix of the transformed frame ##F:=F_0\Phi## with ##\Phi## as above, then
A=\Phi^{-1}A_0\Phi +\Phi^{-1}\Phi'
11. (solved by @Not anonymous ) Show that the number of ways to express a positive integer ##n## as the sum of consecutive positive integers is equal to the number of odd factors of ##n##.12. (solved by @Not anonymous ) How many solutions in non-negative integers are there to the equation:
x_1+x_2+x_3+x_4+x_5+x_6=32
$$13. (solved by @etotheipi ) Let ##A, B, C## and ##D## be four points on a circle such that the lines ##AC## and ##BD## are perpendicular. Denote the intersection of ##AC## and ##BD## by ##M##. Drop the perpendicular from ##M## to the line ##BC##, calling the intersection ##E##. Let ##F## be the intersection of the line ##EM## and the edge ##AD##. Then ##F## is the midpoint of ##AD##.
14. (solved by @timetraveller123 ) Prove that every non negative natural number ##n\in \mathbb{N}_0## can be written as
n=\dfrac{(x+y)^2+3x+y}{2}
with uniquely determined non negative natural numbers ##x,y\in \mathbb{N}_0\,.##15. (solved by @odd_even ) Calculate
S = \int_{\frac{1}{2}}^{3} \dfrac{1}{\sqrt{x^2+1}}\,\dfrac{\log(x)}{\sqrt{x}}\,dx \, + \, \int_{\frac{1}{3}}^{2} \dfrac{1}{\sqrt{x^2+1}}\,\dfrac{\log(x)}{\sqrt{x}}\,dx
\end{bmatrix} = 0
