MHB Math Exam Woe: Unsolvable Bearing Question
  • Thread starter Thread starter Jayden1
    Bearing Exam
The math exam featured a problematic question involving bearings from two lookout points, A and B, to a campfire. The bearings provided led to confusion, as they seemed contradictory, particularly regarding the relative positions of A and B. Participants expressed frustration over the ambiguity of the term "bearing," which is typically measured clockwise from north. Many felt the question was poorly constructed and potentially unanswerable based on the information given. Overall, the consensus is that the question should be reevaluated for clarity and fairness.
Jayden1
So basically, this one question messed me up in my maths exam today. Everything we went over yesterday concerning tangent lines/derivetives I went pretty well in.
The question was. There are two lookout points. A and B. There is a campirefire at a bearing of 40 degrees from A. From point B, the campfire is at a bearing of 20 degrees. From point B, A is at a bearing of 120 degrees. A and B are 10 km apart. Find the distance between A and the campfire.
I tried and tried, but I was unable to do it. Probably because I don't know what bearing is. I thought it meant in relation to north.EDIT: This seems rubbish. Taking these bearings is impossible. If A is located to the left of B, there is no way A's bearing will be more than Bs bearing (in relation to the campfire)
Mathematics news on Phys.org
Agreed, the given data is impossible.
CB
Either I read it wrong, or the examiners will need to change the marks. The only thing I can think of is that maybe they meant take the bearing from C, not A/B. But I am pretty sure this is what it said.
I believe this is impossible however you define bearing here, but I suspect the term is ambiguous. I understand the term bearing without qualification to be an angle measured from N clockwise. I think both the reference direction and the sense of the angle may be different in different contexts.
CB
Well either way. It's far too ambiguous for an exam question if you ask me.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
