- #71
mathwonk
- 11,728
- 1,993
the point quetzalcoatl9 is making is extremely important, and leads to the powerful invariant called de rham cohomology. i.e. suppose we have a vector assigned to each point of X, i.e. a vector field on X, and a smooth mapf from X to Y. if we want to assign a corresponding vector field on Y via the map f, we are out of luck. i.e. take a point y of Y. we want to push over some vector associated to a point of X. but what point do we choose? there is no way to say. we have the same problem with a covector field on X.
but if we have a "covector field" s on Y the story is quite different. i.e. to each point of Y we have assigned a linear function on tangent vectors. now to assign such a covector field on X is easy. if x is a point of X and v is a tangent vector at x, then to evaluate our covector field on v, just apply the derivative (or differential) of f to v and push it over to a tangent vector to Y at f(x). this number is defined to be the value of the pullback covector field, f*(s) at v.
Then we can show also that exterior derivative commutes with pullback. Now define the de rham cohomology group of dergee 1 to be the space of differentials s such that ds = 0, modulo thiose which are of form dg for some function g. then the remarks above show that any smooth map f:X-->Y induces a linear map from the de rahm group of Y to that of X.
thus we have a functor on manifolds. the existence of this functor depends on the fact that covector fields are "contravariant" in category language, or "covariant" in differential geometry language, in either case the point is that they go in the opposite direction to the original map.
it should be obvious to anyone reading this discussion (the choir?) that covariance and contravariance are clearly intrinsic and absolutely essential properties of the objects being discussed.
the existence of this functor has powerful consequences.
for example, by stokes theorem, the de rham cohomology of a disk is zero, and since the form dtheta is non zero on a circle, the de rham cohomology of a circle is not zero. this implies the brauer non retraction theotrem as follows:
if there were a smooth map from the disc onto its boundary, leaving the boundary fuxed, it would induce the identity map of de rham cohomology group of the circle, which also factored through the azero group of the disc, an absurdity.
this then implires the brauer fixed point theorem for the disc.
a similar argument with the solid angle form implies that the antipodal map of the sphere cannot be deformed smoothly nito that identity map of the sphere and this implies that there are no smooth vector fields on the sphere having no zero vectors anywhere.
the subject goes on and on and on... to say whole books have been written about it, is a huge understatement, such as bott - tu, on differential forms, recapturing large parts of algebraic topology via de rham cohomology.
when I was young and energetic, I taught the stuff on vector fields on spheres and brauer theorems, in my sophomore several variables calculus class at central washignton state college.
