Mathematica - How to Go to Next Line Without Running Process?
In summary, to go to the next line in Mathematica without executing the current process, you can use the keyboard shortcut Shift + Enter. This allows you to create a new line in your code while keeping the current input intact for later execution. Alternatively, you can use Ctrl + Enter to evaluate the current cell without moving to a new line.
Ascendant0
154
33
I am trying to run multiple lines input in Mathematica in the free-form input. From everything I read online, you simply hit "enter", but hitting enter runs my process. Both enters, the one next to my letters, and the one on the numerical keypad. Hitting shift+enter also runs it. I can't find anything explaining why this is happening. I would imagine it's some kind of setting I need to change in Mathematica, but I looked through settings and couldn't find one that would be applicable. Help please?
See https://reference.wolfram.com/language/tutorial/InputSyntax.html#14153:
If at the end of a particular line the input you have given so far corresponds to a complete expression, then the Wolfram Language will normally begin immediately to process that expression.
You can however explicitly tell the Wolfram Language that a particular expression is incomplete by putting a ∖ or a  (\[Continuation]) at the end of the line. The Wolfram Language will then include the next line in the same expression, discarding any spaces or tabs that occur at the beginning of that line.
Likes Ascendant0
pasmith said:
Thank you for the information. I can't look at the entire link while working, but I'll be able to later this evening.
I did have a minute to try using the "\" at the end of a line, and it is still processing it as soon as I hit enter. Is that \ maybe only applicable for "Mathematica Input" and not "Free-form input"? I still need to learn the Mathematica language, so I'm using the free form for now. I absolutely plan to learn the language before the end of this year, I just can't at this time.
FAQ: Mathematica - How to Go to Next Line Without Running Process?
How can I insert a new line in Mathematica without executing the current command?
To insert a new line in Mathematica without executing the current command, you can use Shift + Enter. This combination allows you to continue typing on the next line without running the code.
Is there a way to format my code in multiple lines for better readability?
Yes, you can format your code in multiple lines for better readability by using Shift + Enter to create new lines within a cell. This does not execute the code, allowing you to organize and edit your code more clearly.
What is the difference between Enter and Shift + Enter in Mathematica?
In Mathematica, pressing Enter runs the current cell or command, while pressing Shift + Enter allows you to insert a new line within the same cell without executing it. This is useful for writing multi-line code or comments.
Can I use Shift + Enter to add new lines in text cells as well?
Yes, Shift + Enter works similarly in text cells, allowing you to add new lines without ending the current cell. This is helpful for formatting text, writing documentation, or creating structured notes.
How do I run the entire cell after formatting it with multiple lines using Shift + Enter?
After formatting your cell with multiple lines using Shift + Enter, you can run the entire cell by pressing Enter on its own. This will execute all the code within the cell, regardless of how many lines it contains.
13K
