I Mathematical proof for the Lagrangian function
The discussion centers on the relationship between the homogeneity of space and the form of the Lagrangian function in mechanics, specifically arguing that the Lagrangian should depend only on the square of the velocity, v^2. The argument presented suggests that if the Lagrangian function were to depend on position, it would be impossible to find a function that satisfies the conditions imposed by homogeneity. Participants emphasize the need for mathematical proofs to establish the constraints of temporal homogeneity and spatial isotropy on the Lagrangian. There is also a suggestion to explore the implications of multiple symmetries to strengthen the argument. Overall, the conversation seeks a rigorous mathematical foundation for these physical principles.
Silver2007
TL;DR Summary
In Landau's mechanics book, I saw them argue that due to the homogeneity of time and space, the isotropy of space leads to the Lagrangian function depending only on v^2. But i want a mathematical proof for the Lagrangian function independent of position q, time t and velocity vector.
Homogeneity of space:
We have ## \mathcal{L}(\vec{r}, \vec{\dot{r}}, t) ##, and ## \vec{r} \to \vec{r}' = \vec{r} + \vec{a} ##, because homogeneity of space so equations of motion should be the same. Therefore, the Lagrangian function differs only by a total derivative with respect to time ## \Omega(\vec{r}, t) ##:
\mathcal{L}' = \mathcal{L} + \frac{d}{dt}\Omega(\vec{r}, t)
We assume that ## a \ll 1 ##, and we get:
\vec{a} \cdot \frac{\partial \mathcal{L}}{\partial \vec{r}} = \frac{d\Omega}{dt}
At this point, I argue that if the Lagrangian function depends on position, it will be impossible to find an function ##\Omega(\vec{r}, t)## that satisfies the above equation, so the Lagrangian function cannot depend on position. Is my argument above reasonable and coherent?
And I need help with similar mathematical proofs for temporal homogeneity and spatial isotropy. Thanks
How do you suppose these could be proved mathematically? Space and time are related to the physical universe. You can only assume they are homogeneous and isotropic - or prove this from more fundamental physical assumptions. Mathematics would not be compromised if space were non-homogeneous. In fact, you always have to be prepared for evidence that, say, space is not homogeneous.
Sure, but OP is asking under the assumption that the laws of physics are say homogeneous with respect to time and space, then how do you show that this constrains the Lagrangian to be only a function of velocity squared.
If you read my post, you'll see I answered his second question. Which was:
Silver2007 said:
TL;DR Summary: In Landau's mechanics book, I saw them argue that due to the homogeneity of time and space, the isotropy of space leads to the Lagrangian function depending only on v^2. But i want a mathematical proof for the Lagrangian function independent of position q, time t and velocity vector.
What about something like##\Omega(\vec{r}, t)=\vec{r} ^2##?
I suggest proving it first without the total derivative term. To prove there isn't a total derivative difference is harder and I am not sure it is true. I believe you would have to at least use multiple symmetries to show it.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
