Matlab: factorials without for loops or colon
The discussion centers on creating a MATLAB function to calculate the factorial of a positive integer without using loops, the factorial function, or the colon operator. Participants initially express uncertainty about how to approach the problem, particularly without traditional iterative methods. A hint towards using recursion is suggested, which leads to a breakthrough for one participant. The conversation highlights the challenge of implementing the solution while adhering to the specified constraints. Ultimately, the use of recursion is identified as the key to solving the problem effectively.
koryargonic
The Problem: Write a function that finds the factorial of a positive integer without using for or while loops, the factorial function, or the : range operator.
Honestly, I don't really know how to start with this one. If I were able to use a for loop it would be easy, and I don't see how I can do this with conditionals. Any ideas/hints?
Think recursion.
Ooh, thanks. I got it.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
