MATLAB function creation and application
The discussion revolves around creating MATLAB functions for calculating the surface area and volume of various shapes based on user input. The user is struggling with the correct implementation of function calls and the structure of the function files, particularly with defining parameters and managing global variables. Errors encountered include issues with executing the function and unassigned output arguments, indicating a need for proper function syntax and logic. The user is advised to ensure that the function files are correctly defined and that parameters are passed appropriately. The conversation highlights the importance of understanding function creation in MATLAB for effective programming.
GE2014
*see attachment*
Alright, so we just began messing with functions in our class and I'm kinda struggling to grasp this assignment. I believe it should begin like this:
shape = menu('Choose a shape','1: Sphere','2: Isosceles Triangular Pyramid','3: cylinder','4: Cone','5: Rectangular Prisim','-1: Exit');
if (shape<-1||shape>5||shape==0)
disp('Invalid Entry')
end
while shape~=-1
switch shape
case 1
r=input('Enter the radius of the sphere (Inches): ');
if (r<0)
end
sphereArea = surfaceAreaShapes(r);
sphereVolume = volumeShapes(r)
%calling the functions^^^^
%note: I am only showing 1 case of the switch statement and I realize the while loop is . %missing an end.
now that I called the functions, now I have to make em...(surfaceAreaShapes.m and volumeShapes.m) This is where I get super confused. I have a general idea that I'll perform an if/switch statement in order to call up the right formula that corresponds with the shape the user inputs. Just not real sure on the correct formatting of a function.
...Heres what I got for surfaceAreaShapes.m
area=surfaceAreaShapes(radius);
the parameter radius I set doesn't seem like it would make sense considering I will have other things that will need to be put in in order to determine area.
*sorry in advance its not indented properly. That bugs the hell outta me
Updated attempt since class this morning
shapesFunc.m
clc
clear
end
while shape~=-1
switch shape
case 1
sphereArea=round(sphereArea*100)/100;
sphereVolume=round(sphereVolume*100)/100;
fprintf('For a radius of %g\n',r)
fprintf('Surface Area = %g square inches\n',sphereArea)
fprintf('Volume = %g square inches\n',sphereVolume)
end
end
surfaceAreaShapes.m (function)​
global r b h l s w shape
switch shape
case 1
if (r<0)
break
end
%calculate surface area and volume
sphereArea = 4*pi*(r^2);
sphereVolume = (4/3)*pi*(r^3);
end
and here's the error statement I keep getting
Attempt to execute SCRIPT surfaceAreaShapes as a function:
C:\Users\Micheal\Documents\MATLAB\surfaceAreaShapes.m
Error in shapesFunc (line 12)
lolwow I am a dumbass.
might want to put Function in the function file huhh?
Update:
clc
clear
end
while shape~=-1
switch shape
case 1
area = surfaceAreaShapes()
end
end
Function
function area=surfaceAreaShapes(radius);
global r b h l s w
switch shape
case 1
if (r<0)
return
end
end
end
Error message: Error in surfaceAreaShapes (line 2)
global r b h l s w
Output argument "area" (and maybe others) not assigned during call to
"C:\Users\Micheal\Documents\MATLAB\surfaceAreaShapes.m>surfaceAreaShapes".
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
