Max Profit & Number of Items for Maximum Profit: Find Out Now!
  • Thread starter Thread starter recoil33
    Max Maximum
recoil33
The total profit $P, generated from the production and marketing of n items of a certain product is given by:
P = -10800*n-4*n3+600*n2-166
How many items should be made for maximum profit? What is the maximum profit?
Firstly, I think i would find the derivitive of the function.
P' = (-10800)(12n2) + 1200n
P' = (-900)(n2)+100
P'' = (24n + 1200)
Therefore because the second derivitive is positive, it means that it would a relative minimum?
Although, I'm stuck on how i should go upon figuring out the initial question?
I figured out earlier, that (x = 10, x = 90). Can't remember how, because my book with my working out is not with me.
Any help would be appreciated, thank you.
I would double check the calculation of P' and P".
P' = -12(x2 - 100x - 900)
(I converted n to x because i find it easier to work with)
Expand the brackets:
P' = -12x2 + 100x + 900
Therefore:
P'' = -24x + 100
You're still having problems doing your algebra correctly. Double check your latest expression for P' when expanding and removing the brackets.
That was a mistake, i must have typed it without thinking..
P'(x) = -12(n2 - 100n - 166)
P'(x) = -12n2 + 1200n - 1080
P''(x) = -24n2 - 1200
When P'(0) = -12(n2 - 100n - 166)
x = 10, x = 90
P''(10) = -24(10)2 - 1200
= -1440
P''(90) = -24(90)2 - 1200
= -3360
In order to find out the number of items which give the maximum profit, you will have to substitute the two solutions from P' = 0 back into the original expression P(x) for profit. One of these values of x (or n) will give a profit which is greater than the other value of x will.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
