Max Speed of Molecules: 1 Electron Stripped?
In summary, it is not clear why this is in Relativity, but the monotomic hydrogen in the LHC has only one electron stripped and is going pretty darn fast.
DanMP
179
TL;DR Summary
What is the maximum speed we accelerated molecules without striping more than one electron?
I know that we accelerated charged particles very close to the speed of light. How about a full molecule, with at least 2 nuclei and most of the electrons? What is the maximum speed achieved/recorded before the molecule broke apart?
I ask this question because I'm afraid that the maximum speed of travel for complex structures (like us, our robots, etc.) may be much lower than c. If it is much lower, then interstellar travel may be even less possible/appealing.
  • Skeptical
Likes Motore and russ_watters
Speed itself has no effect on a bound system. It can't by the principle of relativity.
It's possible that a large enough acceleration could cause a molecule to break apart, but that doesn't limit the speed you can reach, it just limits the acceleration you can use to reach it.
Likes Motore, Dale, russ_watters and 1 other person
Other side of the coin: since speed is relative, we/earth are already traveling at high relativistic speed in/with respect to some frames/objects.
There is no experimental or theoretical basis for this fear.
Likes DanMP and russ_watters
It's not clear why this is in Relativity, but the monotomic hydrogen in the LHC has only one electron stripped and is going pretty darn fast.
If this doesn't "count", as I suspect it doesn't, we can add this thread to the list of the OP's "guess what I mean" threads.
Likes phinds, Dale, berkeman and 1 other person
So, if the acceleration is low enough we can reach any speed, below c, without braking apart?
I was about to ask for some estimation of this maximum acceleration and to insist about a maximum speed obtained in a particle accelerator for a molecule with only one electron missing (in order to become charged), but I realized that, at high speeds, centripetal acceleration gets very big, so it's impossible to achieve really high speeds (close to c) for molecules, here on Earth, without very large accelerations.
In this case, there is no point to continue here. Thank you for your answer!
What you offered seems to be a proton, and I said:
As measured relative to an ion doing 0.9999c in an accelerator, you are doing 0.9999c. Unless you reject the principle of relativity you already have ample evidence that molecules can reach very nearly the speed of light.
Likes russ_watters
Yes.
You're welcome! This thread is now closed.
FAQ: Max Speed of Molecules: 1 Electron Stripped?
What is the significance of a molecule with 1 electron stripped?
Stripping a molecule of one electron creates a positively charged ion, which can significantly alter its chemical and physical properties. This process is often used in studies of molecular dynamics, spectroscopy, and in various applications like mass spectrometry.
How does stripping an electron affect the speed of a molecule?
Stripping an electron from a molecule can influence its speed due to changes in its mass-to-charge ratio. The ionized molecule may experience different forces in electric or magnetic fields, leading to variations in its velocity compared to its neutral state.
What methods are used to measure the speed of ionized molecules?
Common methods include time-of-flight mass spectrometry (TOF-MS), ion cyclotron resonance (ICR), and laser-induced fluorescence. These techniques allow scientists to determine the velocities and kinetic energies of ionized molecules with high precision.
What factors influence the maximum speed of a molecule with one electron stripped?
The maximum speed of an ionized molecule depends on factors such as the initial kinetic energy of the molecule, the strength of the electric or magnetic fields applied, and the specific mass and charge of the molecule. Environmental conditions like temperature and pressure can also play a role.
Can stripping more than one electron further increase the speed of a molecule?
Yes, stripping additional electrons can increase the charge-to-mass ratio of the molecule, potentially leading to higher speeds under the influence of electric or magnetic fields. However, this also makes the molecule more reactive and less stable, which can complicate experimental conditions and measurements.
