MHB Maxima and minima of a triangle
The discussion revolves around deriving formulas for specific triangle properties. The first query seeks the minimum perimeter of a triangle given the heights corresponding to sides a and b. The second question asks for the maximum height and minimum height corresponding to side b, based solely on the perimeter and height of side a. Participants clarify the need for precise mathematical expressions to address these inquiries. The conversation emphasizes the importance of understanding triangle geometry for accurate calculations.
loquetedigo
Write the following formulas:
a) The minimum perimeter of any triangle (abc) only known heights corresponding to the sides a and b.
b) The maximum height and minimum corresponding to the side b of any triangle (abc) only known the value of its perimeter and height corresponding to the side a.
Mathematics news on Phys.org
Adrian,
I could be wrong, but I think the OP mistakenly posted a question with which they want help here. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
