MHB Maximize Σ(x^2+y)(y^2+x))/((x+y-1)^2)
  • Thread starter Thread starter lfdahl
The discussion focuses on finding the maximum value of T in the inequality involving a cyclically symmetric function of three variables, x, y, and z. The function is expressed as a sum of terms that depend on the variables and is analyzed for its minimum value. It is determined that the lower bound of the function is -3/4, achieved when all variables are equal to specific roots of a quadratic equation. The analysis employs techniques such as minimizing a derived function and polarizing expressions to confirm the bounds. The conclusion emphasizes the significance of the derived minimum value in relation to the original inequality.
lfdahl
MHB
Find the greatest real number, $T$, that satisfies the inequality:
\[\frac{(x^2+y)(y^2+x)}{(x+y-1)^2}+\frac{(y^2+z)(z^2+y)}{(y+z-1)^2}+\frac{(z^2+x)(x^2+z)}{(x+z-1)^2}-2(x+y+z)\geq T\]
for all real numbers $x$, $y$ and $z$, such that $x+y \ne 1$, $y+z \ne 1$ and $x+z \ne 1$.
Mathematics news on Phys.org
[sp]
Let $f(x,y,z) = \frac{(x^2+y)(y^2+x)}{(x+y-1)^2}+\frac{(y^2+z)(z^2+y)}{(y+z-1)^2}+\frac{(z^2+x)(x^2+z)}{(x+z-1)^2}-2(x+y+z)$. Then $f(x,y,z)$ is the cyclically symmetric sum of three functions of two variables, one of which is $g(x,y) = \dfrac{(x^2+y)(y^2+x)}{(x+y-1)^2} - (x+y)$.
It seems like a good guess that $g(x,y)$ will be minimised when $y=x$ (and no doubt MarkFL would produce a "cyclic symmetry" argument to justify that). But $$g(x,x) = \frac{(x^2+x)^2 - 2x(2x-1)^2}{(2x-1)^2} = \frac{x^4 - 6x^3 + 9x^2 -2x}{(2x-1)^2} = \frac{\bigl(x^2 - 3x + \frac12\bigr)^2 - \frac14(2x-1)^2}{(2x-1)^2} = \biggl(\frac{x^2 - 3x + \frac12}{2x-1}\biggr)^2 - \frac14.$$ That has a lower bound of $-\frac14$, attained when $x$ is a root of $x^2 - 3x + \frac12$, namely $x = \frac12(3\pm\sqrt7).$
So the next step is to see whether $-\frac14$ is a lower bound for $g(x,y)$. In fact, $$g(x,y) + \frac14 = \frac{(x^2+y)(y^2+x) - \bigl(x+y-\frac14 \bigr)(x+y-1)^2}{(x+y-1)^2} = \frac{x^2y^2 - 3xy(x+y) + \frac94(x^2+y^2) + \frac{11}2xy - \frac32(x+y) + \frac14}{(x+y-1)^2}.$$ But polarising the expression in the above calculation for $g(x,x)$ gives exactly the numerator of that fraction, namely $$\bigl(xy - \tfrac32(x+y) + \tfrac12\bigr)^2 = x^2y^2 - 3xy(x+y) + \tfrac94(x^2+y^2) + \tfrac{11}2xy - \tfrac32(x+y) + \tfrac14.$$ Therefore $$g(x,y) = \biggl(\frac{xy - \tfrac32(x+y) + \tfrac12}{x+y-1}\biggr)^2 - \frac14,$$ so that $g(x,y)$ has lower bound $-\frac14$, attained when $x = y = \frac12(3\pm\sqrt7).$
The same argument applies to the other two cyclically symmetric functions $g(y,z)$ and $g(z,x)$. So the minimum value of $f(x,y,z) = g(x,y) + g(y,z) + g(z,x)$ is $-\frac34$, attained when $x = y = z = \frac12(3\pm\sqrt7).$
[/sp]
Opalg said:
[sp]
[/sp]
Thankyou, Opalg, for your exemplary analytical solution. You even solved the problem without using the "cyclic symmetry" argument! ;) Great!
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
