Maximizing Efficiency: Comparing AC and DC Sources for Charging Capacitors
Charging a capacitor with a sine wave through a diode is less efficient than using a DC source due to energy losses from the diode's forward voltage drop and resistive losses. The efficiency of AC charging depends on the timing of the circuit activation, as turning it on at zero voltage minimizes losses, while turning it on at peak voltage can damage the diode. The discussion highlights that the analysis of power loss in AC charging is complex and varies with component values. A referenced paper suggests that high efficiency occurs when the input voltage closely matches the capacitor voltage, proposing a formula for DC efficiency that may not directly apply to AC scenarios. Overall, the efficiency of AC versus DC charging requires careful consideration of circuit conditions and component characteristics.
physicsming
A sine wave source charge a capacitor through a diode.
Is it more efficiency than a DC source charging a capacitor ?
base on this
PHP:
https://www.physicsforums.com/attachment.php?attachmentid=17653&d=1235114409
Seems the conclusions being made aren't quite right. You cannot transfer energy through a resistor to the capacitor without loss in the resistor no matter how much of the sine wave period you pass through it.
A DC source charging a capacitor will have less loss than a Sine source charging through a diode. You have a voltage drop across the diodes in the forward bias, and so energy is lost. Not exactly sure why you're comparing this to the figure you attached because that example is charging through a resistor, which holds true for sine and DC sources either way.
thanks for your answer
i need to analyse the efficiency of a AC/DC charge pump,
so i need to know the power loss of a sine wave charging a capacitor firstly.
but the general thesis and data is only analysis the DC/DC capacitor charging loss.
In this paper "A new visit to an old problem in switched-capacitor converters"
propose that the while Vin from voltage source keep close to the voltage of capacitor
it will have high efficiency. the formula in the paper for analysis DC capacitor charging
through resistor is efficiency=1/2(1+Vci/Vin). Vci is the capacitor initial voltage.
Can i use this formula to analysis the efficiency of AC/DC capacitor charge by replace
Vin to Vrms ? thanks
usually there's inductor in series (before the diode bridge) for power factor correction purposes. With inductor you can avoid the loss.
When you are charging capacitor off sine wave through diode and resistor the loss will depend on the time when the circuit is turned on, as well as voltage and resistor and capacitor values. If the capacitor is small and resistance is very small and you turn circuit on at zero voltage, you have no losses (besides the diode's voltage drop). If you turn same circuit on at max phase, you can burn out the diode.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
