physea
- 211
- 3
Hello!
When water flows through fittings like U bends, elbows, etc, is kinetic energy lost and velocity reduced?
How no?BvU said:No
BvU said:Yes there are. However:
Water is practically incompressible, so it can't accumulate and speed has to be maintained. Something else has to give: the driving force.
If the velocity dropped, volumetric flow rate would drop and you would have more water going into a pipe than coming out the other end. What would happen to this missing water?physea said:Why speed has to be maintained?
I am referring to a driving force that sends water at the beginning of a pipe and the end of the pipe is free. Will the liquid exit the pipe at the same velocity? Given diameter is constant, but there are fittings like bends and friction.
Potential energy is lost as the pressure reduces towards the open end. Conservation of diameter requires velocity be fixed and so KE is fixed.physea said:I am referring to a driving force that sends water at the beginning of a pipe and the end of the pipe is free.
BvU said:Yes
Do you believe in conservation of mass? Do you believe that liquid water is very nearly incompressible?physea said:And when the tap generates a flow of 100kg/s, which corresponds to 1m/s (let's say) for 1m pipe diameter, will that velocity of the fluid be the average velocity across the whole pipe, if there are bends etc along the pipe?
100 kg/s is 0.1 m3/s. A pipe diameter of 1 m is ##\pi/4## m2. I get [edit] ##0.4 / \pi ## m/s (ahem...after thinkingphysea said:And when the tap generates a flow of 100kg/s, which corresponds to 1m/s (let's say) for 1m pipe diameter, will that velocity of the fluid be the average velocity across the whole pipe, if there are bends etc along the pipe?
Of course not.physea said:So turbulence does not affect mean velocity?
physea said:Hello!
I'm not following: reduce the volume flux vs what?Andy Resnick said:I think this discussion went off in the wrong direction. It is true that fittings and bends can create a pressure drop that will reduce the volume flux- an extreme example is what happens when you kink a hose. I only have some third-hand ancient engineering books that cover the topic, but there are tables that incorporate pressure drops due to, for example, sudden changes in pipe diameter. The reason, IIRC, is viscous dissipation.
gmax137 said:Yes, the fittings and bends cause pressure drop, and the overall pressure drop affects the flow rate, but it affects the flow rate all along the hose. The velocity downstream of the kink is the same as the velocity upstream, assuming the hose diameters are equal up- and down-stream.
See my post #11.physea said:The velocity downstream and upstream a bend may be equal, but IN the bend? Won't it get affected?
And the turbulence created after the bend, won't affect the mean velocity nearly after the bend?
So, I understand that any losses inside a pipe will be exhibited as pressure drops and not velocity drops? (again I mean average velocity).
It is true to say that, if the volume flow rate is the same and the cross sectional area reduces then the velocity of the water must be higher (Area times speed = flow rate).physea said:The velocity downstream and upstream a bend may be equal, but IN the bend? Won't it get affected?
If there is a diameter change, yes. This the premise of the Venturi Effect.physea said:The velocity downstream and upstream a bend may be equal, but IN the bend? Won't it get affected?
Correct. The mean volumetric flow rate has to be the same everywhere, everywhere and everywhere along the pipe.And the turbulence created after the bend, won't affect the mean velocity nearly after the bend?
Correct.So, I understand that any losses inside a pipe will be exhibited as pressure drops and not velocity drops? (again I mean average velocity).
No. "Cross" is short for "across". As in "perpendicular". Now you're trying to break a definition in order to support a nonsensical and pointless idea you don't want to let go of.physea said:But the cross sectional area shouldn't be always perpendicular to the flow? In a bend, it's not, so maybe there is always a change in the cross sectional area in bends, even though the bore of the pipe is the same?
Flow in pipes is turbulent. Flow meters work. Yes, there's data on it (any flow meter spec sheet provides its accuracy). Please stop trying to argue your way out of a reality you don't like and just accept it.physea said:What happens with rotameters in turbulent flow? Do they over-estimate velocity? Is there any data on this?
russ_watters said:The difference between these two scenarios is often misapplied, but I don't think we're talking about two different scenarios...though frankly it sounds like you switched back and forth between them in your answer.
Unsteady flow is what you have when the flow field is in the process of changing, caused by the system setup changing. E.G., for the second it takes to bend a hose into a kink or few seconds it takes to actuate a valve or variable orifice. Durign this time, the volumetric flow rate is changing and is indeed also not constant along the pipe.Andy Resnick said:That could be. My understanding is that when unsteady flow is created (for example, just after a discontinuous expansion or flow through an orifice in a pipe, either one resulting in a vena contracta), the flow field that exists prior to resumption of steady flow is associated with viscous energy losses. My (ancient) book spends a chapter or so on hydraulic grade lines and energy grade lines. It describes "minor losses" and 'head losses', but isn't very specific on *what* is being lost.
Do a search on "flow meter installation guidelines".physea said:What happens with rotameters in turbulent flow? Do they over-estimate velocity? Is there any data on this?
boneh3ad said:What is being lost is "total head", which is a code word for total pressure.
russ_watters said:It sounds like you are describing undeveloped or developing flow. This is where the velocity profile across the pipe is changing along the pipe due to a discontinuity (in the image in the wiki, an entrance). After the discontinuity, where the pipe becomes uniform again, the velocity profile is still changing, but the average velocity is not.
