Maximizing Flywheel Energy and Power for Passenger Bus Design
  • Thread starter Thread starter Mitchlan
    Energy Flywheel
The discussion focuses on using a flywheel to provide motive power for a passenger bus, with a moment of inertia of 4.0 x 10^2 kgm² and a maximum rotation speed of 3.0 x 10^3 RPM. The maximum kinetic energy stored in the flywheel is calculated to be approximately 68.832 kJ. To determine the maximum distance between stations, the bus's power requirement of 20 kW is considered, leading to the need to calculate how long the stored energy can sustain the bus at an average speed of 36 km/h. The solution involves finding the time the energy can last, which can then be converted into distance. The discussion emphasizes the relationship between energy, power, and distance in the context of bus design.
Mitchlan
In the design of a passenger bus, it is proposed to derive the motive power from the energy stored in a flywheel. The flywheel, which has a moment of inertia of 4.0 x 102 kgm2, is accelerated to its maximum rate of rotation of 3.0 x 103 revolutions per minute by electric motors at stations along the bus route.
a) Calculate the maximum kinetic energy that can be stored in the flywheel.
b) If, at an average speed of 36 kilometres per hour, the power required by the bus is 20 kW, what will be the maximum possible distance between stations on the level?
Part A:
K (Rot)Energy = 1/2 I omega^2
= 1/2 * 4 * 10^2 * 314.159^2
= 68.832 kJ
Part B:
Please help: do I need to find torque and angular displacement, use this to find work then distance?
Any nudge in the general direction greatly appreciated. Thanks in advance.
The bus requires 20kW or 20 kJ/s, so for how long will 68.832 kJ carry it?
That will give you a time, and you are given a speed of 36 km/h so you can get distance.
Great! Thanks for that!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
