MHB Maximizing the weight of a cylinder cut from a sphere
leprofece
A sphere weighs P kg what is the weight of the higher straight circular cylinder that can cut from the sphere?
Answer sqrt(3)P/3
Re: max and min 4
Assuming the mass density of the sphere is constant throughout, how are mass and volume related?
I suggest drawing a diagram of a cross section of the two objects through the axis of symmetry of the cylinder and try to find a relationship between the radius and height of the cylinder with the radius of the sphere. What do you find?
Re: max and min 4
I can do that by pitagorean theoreme
Re: max and min 4
Yes, that's correct. What is the relationship between mass, volume and mass density?
Re: max and min 4
P or mass = d.v
Re: max and min 4
leprofece said:
P or mass = d.v
Yes, and if the density is constant, then we know mass and density are proportional to one another, and so we need only compute the ratio of the volume of the cylinder to that of the sphere, and multiply this by the mass of the sphere to get the mass of the cylinder.
So, what is the relationship between the dimensions (radius and height) of the cylinder with the radius of the sphere?
What is your objective function?
Re: max and min 4
m= d.v
and sphre volume is 4pir3/3
Then m = d(4pir3/3)
r2= R2+ H2
i tried to derive v respect to r
m= d (4pi(R2+ H2)3
looking at the answer i don't know how to eliminate r and h to get (sqrt of 3)m/3 that is my book answer
Re: max and min 4
Look at a cross-section of the sphere and cylinder through their mutual center. You should find that your relationship (using the Pythagorean theorem) between the radius $R$ of the sphere and the radius $r$ and $h$ of the cylinder is incorrect. You have one side of the right triangle wrong.
Re: max and min 4
ohhh I can't find this relationship really I give up sorry
I would appreciate your helping
Re: max and min 4
Here is a diagram...do you see from where I obtained the measures of the 3 sides of the right triangle?
Re: max and min 4
lets see
m= d.v
Then m = d(4pir3/3)
r2= R2- (H/2)2
m= d (4pi(R2- (H/2)2])3/3
now can i derive from here??
Re: max and min 4
I would just maximize the volume of the cylinder first, and then use the relationship between weight density and weight.
$$w_C$$ = weight of the cylinder
$$w_S=P$$ = weight of the sphere
Thus, we may state, given that both objects share the same weight density:
$$\rho=\frac{P}{V_S}=\frac{w_C}{V_C}$$
Hence:
$$w_C=\frac{V_C}{V_S}P$$
You already know the volume of the sphere, so all you need now is the volume of the cylinder. So, our objective function is the volume of the cylinder:
$$V_C=\pi r^2h$$
Subject to the constraint:
$$r^2+\left(\frac{h}{2} \right)^2=R^2$$
So, using the constraint, we may write the volume of the cylinder in terms of 1 variable, and it will be simpler to substitute for $r^2$:
$$V_C(h)=\pi\left(R^2-\left(\frac{h}{2} \right)^2 \right)h=\pi R^2h-\frac{\pi}{4}h^3$$
Now, differentiate this with respect to $h$ and equate the result to zero to determine the critical value(s).
Re: max and min 4
Hence:
$$V_C=\pi r^2h$$
ok I got +/- 2Rsqrt3/3 as critical point
Now we need to put that respect to P:confused:
Re: max and min 4
First, I would demonstrate that this critical value is at a relative maximum. My preference here would be the second derivative test.
Then, you want to evaluate $V_C$ at this critical value, and then substitute that into the formula:
Re: max and min 4
and how does Vs remains??
must I substitute this value too there??
Re: max and min 4
$V_S$ is the volume of the sphere, so you want to substitute its formula there.
Re: max and min 4
OK I GOT THE ANSWER THANKS A LOT(Angel)
