Maximum angle of deflection after collision
The discussion focuses on a collision between two equal mass spheres, where sphere A strikes sphere B obliquely. The relationship between the angles of deflection before and after the collision is expressed through the equation cotβ=((1-e)cotα)/2, where e represents the coefficient of restitution. The user expresses confusion about determining the maximum angle of deflection for sphere A, suggesting that the angle might not always be maximized when α varies. They propose that the condition tan^2 α=(1-e)/2 could indicate the maximum deflection angle. The conversation highlights the complexities of applying conservation laws and the coefficient of restitution in collision scenarios.
osy044
A smooth sphere A impinges obliquely on a stationary sphere B of equal mass. The directions of motion of sphere A before impact and after impact make angles α and β respectively with the line of centres at the instant of impact.
show that cotβ=((1-e)cotα)/2
where e is the coefficient of restitution.
Find in terms of α and e, the tangent of the angle through which the sphere A is deflected, and show that, if α is varied, this angle is the maximum when
tan^2 α=(1-e)/2
conservation of momentum
coefficient of restitution law
I have no problem with first part but the second part seems weird. I think its possible that tan^2 α<(1-e)/2. But anyway using this equation α + β always makes 90 degree. I am wondering if this makes the maximum angle of deflection. but i think they can be less than 90 to make much greater angle of deflection. Please explain it to me.
Please help me
im crying
tt.tt
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
